Page 1 of 3 1 2 3 LastLast
Results 1 to 40 of 104
Thread: Dubai Escort MK2 Duratec
    Dec 2007
    Dubai
    1,678
    29
    Well as Svetlana is pretty well finished, it is time to dust off Gareth's MK2, which has been sitting patiently waiting to be attended to. This will be a joint effort between time-served-apprentice Dobuy and no-time-available Gareth. See if you can work out who is doing the clever bits!
    First off this is the MK2, a fine LHD Philippino sourced shell, with minimal rust and rot, but a fair bit of filler for some reason. They seem to like their filler over in the Philippines!
    Gareth's parts store of useless junk, but with a bigger transmission tunnel already welded in
    Some work already started on the link boxes, spec will be race circuit
    Dobuy's nephew Iain, enlisted as even cheaper labour, generally works for a free lunch and a T-shirt
    Prop shaft and exhaust tunnel tacked in, right hand exhaust might give you a clue as to planned engine
    All welded up
    Finally seat rails tacked in, using 2" box angle section, giving almost perfect width and alignment
    Lots more to come, so stay tuned, this one won't take 2.5 years
    www.gulfpetrolheads.com
    Spanner Monkey fieldstvl's Avatar
    Sep 2006
    The Past
    216
    Re: Dubai Escort MK2 Duratec
    Looking tidy!
    Pit Crew Hoogi's Avatar
    Jul 2008
    Lancashire
    1,590
    Should be a good one to watch............like you were saying, a pretty solid shell to start with
    Nov 2003
    Wirral UK
    6,740
    257
    Good luck with the project
    http://escort.accelerator.org
    Dec 2007
    Dubai
    1,678
    29
    Little update
    Got stuck into sorting out the tubs and tarmac arches, thought I would try the Oxy-acetelyne torch to chop out the sill corners, but in the end went back to the trusted 1mm cut-off discs
    Tidied up the arch to the correct size for the Rally Design Tarmac arches, these will be riveted on as we move towards paint
    Arches trial fitted
    Inner tub formed
    Should be big enough for up to 17 inch wheels if need be, although Gareth plans to run 15's
    Gareth welding up the sides and turrets. We decided to make the turrets, which turned out to be a bit of a mare, with hindsight we probably should have just bought them and saved a load of fabrication and head scratching time.
    The chassis rail is knotched back, so again plenty of clearance
    Pretty well finished tub and turret
    Little fillets to firewall the sides and add strength
    Going to blast the car soon, as there is a fair bit of filler inside and outside that needs removed. Also waiting for the roll cage to come from blighty.
    Nov 2003
    Wirral UK
    6,740
    257
    Looking good already, nice work
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Here we go again................................
    They like their filler over here in Thailand... must be an Asian thing!
    Dec 2007
    Dubai
    1,678
    29
    OK, wee bit of an update from sunny Dubai's only Ford Escort service center
    Got my spare block in to make the engine mounts
    Type 9 used to mock up for Quaiffe Sequential that is in the post
    LH engine mount being fitted to Chassis rail, wish I had done this on my car
    RH mount finished
    LH mount finished, was a bit of a pain, as I had tacked it all together, but it moved during weld up, so had to cut the engine plate off and do it again.
    Meanwhile Gareth, was busy with his Atlas Axle narrowing
    Fully floating hubs, just in case he decides to go off-piste
    Diamond brackets welded up, he does quite nice work our Gareth, when you can get him out of the office!
    Some JCB spares arriving from the UK
    revealing
    Something a bit more like a couple of new Duratec's from Powertec Engineering http://www.sports2000-srcc.com/proseries/engine.cfm
    Good price at Ģ1800 each shipped to Dubai, unlike the local dealer that quoted me Ģ8600 for the same thing, but they did offer 20% discount, hard to see how I could turn that one down.
    Manifold from eBay, not bad for Ģ160, bit tight on the inner wing, so chopped 3 cm's out of it and re-welded at the manifold, should be fine for the 200 rear wheel horsepower we are aiming for.
    Oct 2008
    Sunderland
    155
    Another interesting thread from you,watching with interest
    May 2008
    Wales
    A few more parts
    Nov 2003
    Wirral UK
    6,740
    257
    That manifold looks like a nice bit of kit!
    Dec 2007
    Dubai
    1,678
    29
    hmm, perhaps not the nicest in the world, but it was seriously cheap off eBaySo off the shell went to the blasters to remove all the filler..
    Had a few repairs before, but shell is pretty solid
    Not quite sure just why they welded up this part
    Looks like it has had a bit of a light smack on the rear end, but repair is fine
    Roof and gutter need a bit of a re-repair
    Likewise door pilar
    Suspension verticals need a bit of a patch
    Mostly solid, with a few little repairs required
    Brazing torch has been used to strengthen shell
    Floor a bit beaten about, but solid
    So onward with the repairs, first a couple of patches for the front suspension verticals
    Bade from 2.5mm steel so should be plenty strong
    Chopped out the old top mount to repair and give a bit more clearance for the exhaust, so now there is just room for the roller bearing top mount.
    Also repaired the bubble bottom rot
    Repaired the roof and gutter
    Still needs a little fettle-ing, but will sort that out before paint.
    Radiator lowering panel fabricated
    Got stuck into the cage, was supplied as a kit from the UK, so saved a lot of time not having to bend the main hoop and door pilar bars
    So that's it for the moment, need to get Gareth to get the rear axle mounted up ont he links, so we can finish off the rest of the rear end, then get in the rest of the cage.
    Tyre Kicker Dan649's Avatar
    Mar 2011
    Dubai
    29
    Looks Familiar???
    Dec 2007
    Dubai
    1,678
    29
    OK, so some more pictures, Gareth decided that it was time to get serious, so has been cracking on with the metal work
    Started in on the firewall and decided that the transmission tunnel was too wide for the seat, so out that came
    Firewall in place
    And a little front wheel well modification
    Should now give decent full lock clearance
    And a new tunnel was made and promptly put in the scrap pile so we are on version 3 at the moment
    Tunnel version 3
    Tunnel Done.
    Dash support bar done.
    Front triangulation finished
    and the rear cage cross
    Version 2 of the Seat bars in, first ones, along with the tunnel did not allow for full width of seat
    A little progress, seat belt bars fitted to cage,
    Tank bolted in ready to sort out filler
    Spanner Monkey wildman's Avatar
    Nov 2006
    cambs
    64
    286
    18
    hello dobuy could you tell me where the engines came from i googled powertec engineering and found they are a company in my near me in peterborough england , they do radical sportscars ?? thanks
    Mar 2004
    Harlow, Essex
    14,285
    318
    Oi.. when did i ship some of my 4 link front brackets out to you
  17. The Following User Says Thank You to Retromotorsport For This Useful Post:
  18. #17
    Jul 2006
    bristol
    10,882
    892
    Quote Originally Posted by wildman View Post
    Yeah come on spill Ģ1800 for a duratec??? what spec is it what came with it?
    Another good project by the way
  19. #18
    Nov 2008
    Adelaide, Australia
    1,331
    96
    gee I thought my roll cage was heavy duty....i like...nice work!
  20. #19
    Dec 2007
    Dubai
    1,678
    29
    Sorry my Bad, it should be PowerTorque
    The engines are brand new, unmolested Focus engines, with standard 11.9:1 pistons.
    They are about the same price (1800 quid) shipped to Dubai, as you would pay in the UK shipped to your home, including VAT.
    Yes , I think it is fair to say that Gareth is suitably impressed by your Tarmac link boxes and copied them a leetle, copyright cheque is on the way by international carrier pigeon....
  21. #20
    May 2008
    Wales
    Quote Originally Posted by Retromotorsport View Post
    Ive been storing the information on those link boxes for a long time, you may remember me picking your brains, that was back when i first thought about starting this project the problem i had is i couldn't get them folded as narrow as the dimensions you gave me. but i think they turned out OK.
  22. #21
    Mar 2004
    Harlow, Essex
    14,285
    318
    Ahh yes i do remember now.. Yes they are a pain to get folded, the people I get to do my lazer cutting had to outsource the folding even though they have folders there.
  23. #22
    May 2008
    Wales
    Well its been a while but the project hasn't stopped, we have been working on it. All fab work finished and the car has gone to Paint been there 3 weeks and it doesn't look like i will get it back for another week or 2.
  24. #23
    May 2008
    Wales
    A few more
  25. #24
    May 2008
    Wales
    :d
  26. #25
    May 2008
    Wales
  27. #26
    Nov 2003
    Wirral UK
    6,740
    257
    Nice work on that shell
  28. #27
    Jul 2006
    bristol
    10,882
    892
    Forgot you was doing this one some good progress going on bud
  29. #28
    Mechanic davblue's Avatar
    Aug 2009
    ayrshire
    673
    nice project there
    has been alot of thought has went in to it.
    keep up the good work.
    will keep watching
  30. #29
    May 2008
    Wales
    Thanks for all the comments, and a massive thanks to Neil for pushing me to get on with it and starting the project.
  31. #30
    Apr 2004
    4,346
    479
    It's coming along now... Some great work going on
  32. #31
    Spanner Monkey sgallywag's Avatar
    Mar 2009
    sidcup,kent
    35
    410
    16
    this car makes me cry....good fab work tho boys...
  33. #32
    Pit Crew Decade Plus User raymondmarble's Avatar
    Sep 2005
    Dundee
    1,029
    116
    Quote Originally Posted by dobuy View Post
    We have it in writing
    But fast progress so far and looking great! Keep it up
    Please 'Like' us on FB!
    https://www.facebook.com/pages/Jana-Kitchen-UK/393933930736835?ref=hl
  34. #33
    May 2008
    Wales
    Not a lot of progress getting it back from paint shop on wednesday
  35. #34
    May 2008
    Wales
    after several weeks in the body shop i finally have it back
  36. #35
    Dec 2007
    Dubai
    1,678
    29
    bout bloody time you slacker....
  37. #36
    May 2008
    Wales
    Today ive been doing a jigsaw with lots of bits missing.
  38. #37
    Dec 2008
    Finland
    2,106
    62
    I wonder why people donīt paint the front panel behind the grille black more often. I really like it.
  39. #38
    Jul 2006
    bristol
    10,882
    892
    lovely bud
  40. #39
    Spanner Monkey genRS2000's Avatar
    Jan 2009
    Perth Western Australia
    67
    438
    30
    Quote Originally Posted by Roadsport View Post
    Did mine
  41. #40
    Dec 2008
    Finland
    2,106
    62
    I did too back in the day when I had a mk2. Did not like the yellow shining trough the grille
