Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 41 to 80 of 206
Thread: SFS 447V Harrier Project
  1. #41
    Feb 2011
    Monmouth
    Re: SFS 447V Harrier Project
    Just found the thread - I owned this car in late 1998 to mid 2000. I regretted selling it as soon as I did! It was very very solid when I had it, no sign of rust anywhere.
    Bought it with a blown diff, got it on the road and ran course opening car for the East Anglian Classic rally in it (in 2000 I think). It had a 2.0 Pinto with some mods.
  2. The Following User Says Thank You to richmcl For This Useful Post:
  3. #42
    Apr 2020
    Essex
    210
    Great build
  4. #43
    Loads more have been done recently Simon will update the current progress soon.
  5. #44
    Spanner Monkey SimonD's Avatar
    South East Kent
    230
    22
    Quote Originally Posted by richmcl View Post
    Attachment 85671
    Hi Richmcl,
    Yes, unfortunately it looks like the car was very well used after you sold it. The company that did a lot of the conversion work didn't do the car any favours because their work was complete crap.
    Thanks for getting in touch though
  6. #45
    South East Kent
    230
    22
    Update on the brake and clutch mounting plate, I've created a template for dilling the holes for nice even spacing. We have also added a small tab into the rear of the plate, the fit is now so much nicer.
  7. #46
    South East Kent
    230
    22
    I've ended up selling the Gartrac pedal box I had for a floor mounted Tilton setup, with the Tilton pedals I can have my seat as far back as it will go.
    Probably should have tried to fit this before welding in the front roll cage foot but the cardboard template my dad make worked a treat
  8. #47
    South East Kent
    230
    22
    This is by far the biggest achievement on the car so far, both new tunnels are fitted and welded in.
    You can't believe the time spent on getting these to fit nicely, with a really clean return fold underneath the car.
    Its really starting to look like a car again
  9. #48
    Feb 2011
    Monmouth
    Was quite surprised to see how bad it had got (never mind the bad workmanship), especially as it hasn't seen much action on the road since I sold it - it must have been stored outside for some time.... Have you got the odometer - how many miles on it?
  10. #49
    South East Kent
    230
    22
    Unfortunately a lot of the parts were lost including the clocks when the car was moved to a new storage unit around 2010
  11. #50
    South East Kent
    230
    22
    More cardboard templates reinforced with tig welding rods, I'm surprised that I couldn't find anyone making these but a local company folded it up for.
    They need a few dimple die holes and the battery tray mounts between the diff tunnel and 4 link box needs doing before these are welded in
  12. #51
    South East Kent
    230
    22
    Seat bars going in anyone that has fitted these will know they are horrible to install, they are so time-consuming. Both sides have ended up even because of the cage the passage seat can't go back any tougher
    And as of 2 weeks ago no longer FIA/MSA Approved but that's life, there definitely not coming out now
  13. #52
    2,659
    268
    Quote Originally Posted by SimonD View Post
    Really??? What have they changed now, how do they want them fitted then?
    Larger reinforcing plates maybe?
  14. #53
    South East Kent
    230
    22
    Check out page 164 in the new 2020 Blue book, pain in the ass loads of people are having to cut the seat bars out. I have no plans to race the car so Im not changing them now they are in.
    The main part they have changed is losing the overhanging seat brackets for a bolt through the centre of the tube
    https://www.motorsportuk.org/wp-cont...ook-2020-1.pdf
    2.2.1. Supports must be attached to the shell/chassis via at
    least 4 mounting points per seat using bolts with a minimum
    diameter of 8mm and counterplates, according to drawing No.
    K32 or K64. In the case of drawing No. K64 the end plates may
    alternatively be welded to the counterplate. The minimum area
    of contact between support, shell/chassis and counterplate is
    40 sq cm for each mounting point. In Series Production Cars
    manufacturers’ standard seat mounting points may be used. If
    quick release systems are used, they must be capable of
    withstanding vertical and horizontal forces of 18000N, applied
    non-simultaneously. If rails for adjusting the seat are used, they
    must be those originally supplied with the homologated car or
    with the seat
  15. #54
    South East Kent
    230
    22
    The photos of the new kit Motorsport Tools have made shows the changes well, it makes sense a lot of people welding its up to scratch for something like this. They must have seen the old design ripping off the tube
    https://www.motorsport-tools.com/fia...ket-mount.html
  16. The Following User Says Thank You to SimonD For This Useful Post:
  17. #55
    2,659
    268
    Okay yeah I see what you mean. Drawing 64 is how I did mine years ago, but I welded some small angle with captive nuts to the sides of my square tubes to bolt the seat mounting kit to before bolting the seats to that.
  18. #56
    Feb 2011
    Monmouth
  19. #57
    May 2016
    Germany
    288
    63
    Nice welding! Fantastic build so far! Great progress in short time.
  20. #58
    South East Kent
    230
    22
    I can see why they have done it, I know its upset a lot of people that have had their cars painted and so on
    That's a real shame. It had the proper RS pod in it.Attachment 85711
    It really is but hopefully what we're doing to the car will make it back into a nice car again
    Quote Originally Posted by skmotorsport View Post
    Thank you
  21. #59
    South East Kent
    230
    22
    More progress made on the base for the pedals today, and the mounting for the battery tray
  22. #60
    South East Kent
    230
    22
    Navigators footrest mounts have been made up this week on the lathe along with a template to help weld them in.
    This car is turning into a porker, the time has come to put dimple holes in the panels where it doesn't look out of place
  23. #61
    South East Kent
    230
    22
    I have been very lucky and won an online competition for an ECUMaster ADU 5 LCD display, I still can't believe I won it!
    The software is really good, you can create any design/layout you want, I've had a quick go and created two pages. One for the road and a second page with more info for the track.
    This will look great in the car, I think its going to be mounted to the steering column just because the 5" screen isn't that big and I've packed a lot of info into the screen
  24. #62
    Mar 2004
    Barking Essex
    9,034
    262
    I fitted that when I had the car in 87 👍
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
  25. #63
    Feb 2011
    Monmouth
    Quote Originally Posted by cossymax View Post
    I fitted that when I had the car in 87 ��
    Crazy how much they cost nowadays. I had an RS pod in my other Escort at the time as well, they just weren't that hard to get hold of.
  26. #64
    South East Kent
    230
    22
    Loads more progress made on the car, a huge amount of work and welding to get the car back to where it was when we started work on the car.
    Needed a change of scenery so started looking at the rear axle, only got the toe correction & caliper brackets tacked on so far but it's nice to be working on something other than the shell
  27. #65
    2,659
    268
    Nice idea with the harness/belt eyes set into the cage feet.
  28. #66
    Jan 2012
    Aberdeenshire
    417
    Looking good. Won’t be long and she will be in paint
  29. #67
    3,241
    Interesting axle / diff brace arrangement - never seen it done that way! Reasoning behind it?
  30. #68
    25,116
    unless its a way to try and alter toe i cant see the point, rose joints being movable wont brace against bending of the axle
  31. #69
    South East Kent
    230
    22
    Its a toe correction kit with left & right-handed threaded rose joints, it allows you to put the axle under tension to set toe and minimise the tube flex under hard acceleration.
    They work very well but you have got to be careful not to over adjust and bend the axle tubes
  32. #70
    South East Kent
    230
    22
    The harness eyes idea came from the DME Escort build on Facebook, if you haven't seen this build its amazing!
    Quote Originally Posted by donnie View Post
    Thanks, still along way to but its definitely getting there now
  33. #71
    With a toe correction kit, it will stop axle spread under high grip conditions 2mm deflection per side max giving 4mm toe-in, this mk2 will be on 9-inch slicks for the rear, a Duratec 250-260bhp engine is already built to get it on the road then the 350bhp upgrade to follow.
  34. #72
    2,659
    268
    Ok thanks. I don't do Facebook.
  35. #73
    South East Kent
    230
    22
    You don't need an account to look at the photos, if the Facebook popup appears you can click "Not Now" and it goes away
    Amazing work is done by these guys
    https://www.facebook.com/pg/DunneMsp...=page_internal
  36. The Following User Says Thank You to SimonD For This Useful Post:
  37. #74
    South East Kent
    230
    22
    Didn't really achieve anything this weekend apart from learning a lot about Atlas axle widths and how that relates to wheel widths and offsets. I was really hoping to get away with a 52" axle and still get a nice dish on the rear wheels by playing around with the offsets but that's not going to happen with the 52" casing.
    I have only brought the front wheels so far which are a 15x8J with 0ET, because they are a 0 ET they are good starting point to work out what I can get away with tarmac arches and the 52" casing. You can see in the photo the 0 ET wheel is almost touching the arch, using an online offset calculator I would need a positive offset to be able to fit the 9J wheel which isn't any good. Looks like the tools we make to push the tubes out are going to be used again to convert this casing into a 50" version to gain more arch clearance.
    It's nice to be getting to the more interesting parts of the build
  38. #75
    2,659
    268
    Took me a while to get round to having a good look at that. It is a lovely build isn't it..
    As is Yours too! Some great work going on here, keep at it. It'll all be worth it in the end..
  39. #76
    Jan 2012
    Aberdeenshire
    417
    Brilliant as always and coming on strong, must say you are a dab hand on the torch
  40. #77
    South East Kent
    230
    22
    There work is amazing isn't it, I have got a lot of ideas from that build.
  41. #78
    South East Kent
    230
    22
    Thanks donnie
  42. #79
    Dec 2013
    kent
    82
    This would fit in nicely with the Modified Ford race Series
  43. #80
    South East Kent
    230
    22
    Quote Originally Posted by goldy View Post
    I'd love to race it at some point in the future
    I'll try and update the post soon with the progress that's been made on the shell
