Results 1 to 14 of 14
Thread: Blowing out smoke
    Apr 2004
    manchester
    594
    33
    Blowing out smoke
    Hi all
    Ever since I’ve had this xflow engine it has ‘breathed’ from the catch tank ,
    i thought it was because the block breather went straight to the catch tank , so I re did it
    so now I have the block breather going to the back of the rocker cover and then an oil filer cap with a breather pipe to the catch tank .. this is vent at the top via a small breather type filter ...
    engine is only a mild spec .. plus 40 HC pistons , GT big valve head , port and polished running twin 40’s
    it doesn’t fill the catch tank with oil , the smoke from the breather is fairly bad .. more so at it gets warm.
    i don’t think the engine is overfull of oil , but the sump has been altered slightly.. it’s in a TVR
    so am unsure of the capacity
    there is smoke out of the exhaust will revved
    thoughts please ... surely worn rings would make it smoke all the time from the exhaust
    Re: Blowing out smoke
    Quote Originally Posted by chrisb View Post
    depends on whats wrong with the rings, if the oil control rings are still doing there job you wont get smoke out the exhaust, if the compression rings are worn you will see blow by (smoke) out the breathers
    Apr 2004
    manchester
    594
    33
    Soon as I can find my compression tester I’m going to check they are all evenly matched
    Apr 2004
    manchester
    594
    33
    Apr 2004
    manchester
    594
    33
    Hi Graham..
    did a compression check think I may have an issue done with all plugs out cranked for approximately 10secs
    Number 1 110
    Number 2 115
    Number 3 105
    Number 4 125
    Thought they seem low and I expected higher readings
    those are low
    Apr 2004
    manchester
    594
    33
    those are low
    Yup that’s what I thought .. it popped a bottom hose off a while back and over heated .. thought it had just done the head gasket. Had the head skimmed and pressure tested and came back ok , looks like it may of done more damage ..
    Apr 2004
    manchester
    594
    33
    those are low
    Oct 2018
    Midlands
    291
    Did you have throttles wide open doing test
    Apr 2004
    manchester
    594
    33
    Quote Originally Posted by Theyellowmex View Post
    No closed throttle.. will recheck with it open ..
    Apr 2004
    manchester
    594
    33
    Rechecked this morning from cold
    Numbers 1,2 and 3 have 130 whereas number 4 has 160..
    So I'm thinking the bores or rings must be worn for it to have the heavy breathing issue.. With light ish smoke from the exhaust
    3,241
    Going on a 10% spread - 1, 2 and 3 deffo look goosed / rings severely cooked!
    Apr 2004
    manchester
    594
    33
    Probably happened when a poorly repaired hose by the previous tit popped off ..
    Think I’ll just rebore the engine to plus 90 rather then risk glaze busting and new rings .. 1700cc ( well 1690 )
