Results 1 to 8 of 8
Thread: T9 Gearbox temperature sender
    May 2016
    Germany
    288
    63
    i´m for some infos how and where to fit the temperature sender unit at my T9 5-SPeed Gearbox. Does anybody do this before?
    May 2016
    Germany
    288
    63
    Re: T9 Gearbox temperature sender
    Did anyone else do this before... sounds better
    2,659
    268
    I don't know of anyone that ever has..
    3,241
    Quote Originally Posted by skmotorsport View Post
    Have to ask why? And what are you going to do with the info if you do fit one? Who knows the temp spec's so could be too cool or too hot .............. then how to cool it?
    May 2016
    Germany
    288
    63
    In fact it is just for optical reasons. I don´t wanna build a competition car, so the gear box oil will never reach it´s limits. But in fact I build MY own car with my visions how it shold look inside and outside.
    Thats why I want to use 3 instead of two instruments in the center console!
    Click image for larger version Name:	IMG_4439.JPG Views:	41 Size:	124.1 KB ID:	84768 Click image for larger version Name:	IMG_4443.JPG Views:	41 Size:	114.7 KB ID:	84769
    Click image for larger version Name:	IMG_4445.JPG Views:	42 Size:	135.4 KB ID:	84770 Click image for larger version Name:	IMG_4446.JPG Views:	42 Size:	126.7 KB ID:	84771
    So in fact I will be the first crazy german ever who will do it...why not!
    3,241
    Wouldn't engine oil temperature be of more use? - and you still keep your 3 dials!
    May 2016
    Germany
    288
    63
    The 3 extra Dials are Oil Temperature / Battery Voltage and if it works, Gearbox Oil Temperature.
    I have the RS Dash were the Oil pressure, coolant temp an fuel is in.
    May 2016
    Germany
    288
    63
    I found theese pictures in a MGA Forum! How to fit an Sump plug! I could use it for both! Sensor hole and drain Plug!
    Click image for larger version Name:	Oil drain hole.jpg Views:	39 Size:	30.2 KB ID:	84772 Click image for larger version Name:	Drain plug.jpg Views:	39 Size:	26.6 KB ID:	84773
    With the car raised, drill a pilot hole (2mm drill will do as its into aluminium) in the position shown. You can happily drill through the case to about 2.5cm depth without fear of hitting any of the gears. The casing is probably about 1cm thick in this area and has an internal flange behind so I am told. Allow the oil to drain. This could take an hour or so with the small pilot hole. You could of course enlargen it at this stage but the drill will spray oil when turning. One point to consider is the swarf. Drill at low speed and remove frequently to wipe the swarf off.Once the oil has drained enlargen the hole to a suitable size for an appropriate tap. Tap the hole. Proceed with care and remove frequently to remove the swarf. Smooth off the casting lip if it is likely to foul the bolt head. Fit the bolt and washer (shorten if necessary to about 1.5cm thread depth, although I don't think the length is critical). Do not overtighten as it's only an alloy casing.Refill with SAE 75-90 semi synthetic oil. The filler hole is on the left side of the gearbox about 15cm forward of the new sump plug. Fill a squeezy bottle with the oil. Attach a plastic pipe, locating the other end in the hole. Squeeze the oil in uphill until oil drains out of the hole. The gearbox will take up to 1.9L oil maximum
