Results 1 to 8 of 8
Thread: Type 9 removal from Mk2 Escort
    Oct 2008
    Cheshire
    82
    What’s the best way of removing a 5 speed type 9 from Mk2 Escort with a Blacktop Zetec fitted?
    Will it come out without removing the engine?
    The car was a manual before the conversion, not the big auto tunnel.
    2,656
    267
    Re: Type 9 removal from Mk2 Escort
    Quote Originally Posted by jb644 View Post
    I'm guessing here, but It might if you drop the crossmember down on some long studs. Other than that it'll be engine out aswell, unless it has a quick release bellhousing in which case the bellhousing is staying in the car and you can just unbolt the gearbox from the back of the bellhousing.
    Jun 2007
    Whitley Bay
    3,437
    81
    Replace the cross member bolts with longer ones 1 by 1 and drop the engine as low as possible this will give you the most clearance without having to crane lift the engine and fiddle around at an angle
    Screaming 1300 mexico rep
    If you drop the x-member don't forget to disconnect the steering column. I normally have to work on my own with such jobs and find it is easier just to drop everything on the floor engine and all onto dolley on castors. Rather than lifting things up and out.
    Wrestling a gearbox on your own on your back is no fun.
    Oct 2008
    Cheshire
    82
    Yes, I’ve heard about lowering the xmember on Pinto and Xflow engined cars, but wasn’t sure it would work with a Zetec.
    3,237
    Effectively same bolt pattern used so exactly same methods work. Must drop X member to access bolts at top of bellhousing but be carefull as the retaining nuts within the chassis legs are only tacked in place - too much rocking around and they shear - not a good day!
    Apr 2013
    S Wales
    230
    431
    If lowering the crossmember, I also remove the steering wheel.
    Oct 2008
    Cheshire
    82
    Thanks for all the replies.
