Type 9 Retro ford release bearing
Does any body know what release/thrust bearing Retro ford supply with there clutch kits?
I might need to replace my bearing and need to know the part number.
I believe the flywheel is redrilled to take a standard pinto clutch.
Re: Type 9 Retro ford release bearing
Will it be a standard pinto clutch thrust/release bearing?
You’re right it’s just a standard Pinto Clutch Thrust / release bearing. Retro Ford supply Borg and Beck standard clutches, I believe the thrust bearing comes with it. You can get a replacement (not sure of brand) from places like Burtons. They list one under their own brand. They are more than likely available through most motor spares shops. Hope that helps
