Results 1 to 14 of 14
Thread: injector dead time Bosch 403 greys
    Dec 2013
    spain
    17
    hello.
    i do not know if is correct place to ask. but in other forums i did not get answer...
    someone could share info About Bosch 0280150403 Greys injectors? please
    i would like know INJECTOR DEAD TIME.
    best regards
    Dec 2015
    Denmark
    Re: injector dead time Bosch 403 greys
    Hi
    What is injector dead time?
    The time required for the injectors to begin to open is referred to as 'Injector Dead Time”. The injector dead time is dependent upon several variables such as the characteristics of the actual injector itself, plus external influences such as fuel pressure and particularly supply voltage.
    Regards
    Kim Bonde
    4,888
    Think Mr. runner knows what it means but he is asking for a value and/or a graph.
    Dec 2015
    Denmark
    Hi
    To MR.runner
    Look at this page : Fuel Injector Lag Time - Injector-Rehab
    There is no info for Bosch 0 280 150 403.
    Mar 2012
    2,118
    Usual, you just don't need to know it.
    4,888
    Well he wants to know it otherwise he wouldn't be asking.
    Dec 2015
    Denmark
    Mr.runner where are you .
    Is for use in a new engine mangement ??
    Look in the batteri adder in L6/L8 map.
    Dec 2013
    spain
    17
    Hi Friends, i am from Spain
    need dead time data at all voltajes and about 30psi.
    yes would like use them in my standalone ECU. now have some issues with idle AFR when batery voltaje change.
    look l6 , l8 or p8 with Greys tables of battery correction will be solución.
    Someone could share good 403 injectors .Bin map and .xdf
    Will use tunerpro to read It.
    (i can not read my good P8 pectel board chip , haven't moates)....
    Jul 2016
    Spain
    12
    Send me your bin file or post it here (just the eprom, without the board), I can decrypt this one and send to you the battery correction table.
    Dec 2013
    spain
    17
    hi lunes86, i have not eprom reader to read my p8 greys chip.
    Mar 2012
    2,118
    Any injector voltage compensation that comes close to the same resistance will do the job. Once a more or less correct number is fitted (even if it isn't close) closed loop Lambda WILL work. Even if you fill all the same numbers, closed loop will still work. Batt. voltage should never vary so much that this would be the issue.
    I guess something else is wrong, Lambda in bad position etc...
    Jul 2016
    Spain
    12
    Which part of Spain? I'm from Coruña, so if you are near here you can read your chip with my reader
    Dec 2013
    spain
    17
    Hi Mr. lunes86, too far, about 500km away, but I appreciate your offer.
    I am making records with the data logger and executing corrections.
    Now I am getting good result. but I would prefer to use values ​​provided by the manufacturer of the injectors.
    or an experienced tuner with a good reputation.
    what reader do you use? moates?
    Jul 2016
    Spain
    12
    No problem!
    No, I have a Dataman reader.
