Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 41 to 80 of 376
Thread: Mk2 Duratec Escort
  1. #41
    May 2010
    North Yorkshire
    213
    17
    Re: Mk2 Duratec Escort
    Engine and box ready for first fitting
    ​enquiries@flintec-eng.co.uk
  2. #42
    Nov 2003
    Wirral UK
    6,740
    257
    Cracking work mate
    http://escort.accelerator.org
  3. #43
    Spanner Monkey johnaboyy's Avatar
    Sep 2009
    saltcoats
    61
    381
    16
    That will look the dog's danglie's under the bonnet!!!!
  4. #44
    May 2010
    North Yorkshire
    213
    17
    Big thanks to Paul for calling in last night and motivating me to get the engine in. Got it dropped in and roughly in place last night before beers. spent all of today measuring and adjusting the position, measuring again, cutting, jacking and more measuring. Finally happy with the position. re fitted the steering column and trial fitted the manifold which is fouling the existing chasis engine mount on the o/s. going to have to cut it off tomorrow and reloate it around 80mm further forward to clear the lower part of the manifold. once thats moved i can get some mounts fabricated
    Click image for larger version Name:	IMG_0902.jpg Views:	37 Size:	229.4 KB ID:	47787
    Click image for larger version Name:	IMG_0909.jpg Views:	35 Size:	143.6 KB ID:	47788
  5. #45
    May 2010
    North Yorkshire
    213
    17
    Got the offending bracket removed this morning and the manifold fitted. engine and gearbox mounts next
    Click image for larger version Name:	IMG_0912.jpg Views:	34 Size:	221.4 KB ID:	47806
  6. #46
    Sep 2009
    saltcoats
    61
    381
    16
    Bet your glad the manifold is on!!. Keep up the good work, cant wait to see more progress.
  7. #47
    Mar 2004
    Barking Essex
    9,033
    262
    Nice tidy install, and cracking car
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
  8. #48
    Nov 2003
    Wirral UK
    6,740
    257
  9. #49
    Jul 2006
    bristol
    10,882
    892
    Cracking job bud I'll be starting mine in the winter.
  10. #50
    May 2010
    North Yorkshire
    213
    17
    Thanks for comments guys. Started on the engine mounts last night and this was what i had in mind
    Click image for larger version Name:	EngineMountExample.jpg Views:	34 Size:	22.1 KB ID:	47960
    the plan is to use 15mm round bar to create 4 spurs, then to box them in using 2mm sheet. this will be so much easier than cutting large tube to suit the geometry........ and i think it looks much nicer
    Quote Originally Posted by trig View Post
    thanks trig, have you made a final choice on what motor your using?
  11. #51
    May 2010
    North Yorkshire
    213
    17
    Made these screw jacks at work to aid the positioning and leveling of the engine before welding the mounts up
    Click image for larger version Name:	IMG_0917.jpg Views:	37 Size:	194.8 KB ID:	47975
    This is as far as we got last night with the mounts. 2 spurs on each side. going to get the engine out next and finish them off on the bench
    Click image for larger version Name:	IMG_0915.jpg Views:	34 Size:	208.8 KB ID:	47976
    ................and whilst i had my welder working on the car got him got float over the cage welds with the tig to tidy them up
    Click image for larger version Name:	IMG_0916.jpg Views:	33 Size:	206.3 KB ID:	47977
  12. #52
    May 2010
    North Yorkshire
    213
    17
    Wiring loom has arrived from the states. its made by a company called Kwik Wire and are mainly used in the hot rod scene. The loom has the following 14 circuits
    Brake Lights
    Radio Constant
    Horn
    Headlights
    Dome Light
    Fuel Pump
    Radio
    Gauges
    Wipers
    A/C and Heat
    Hazard Light
    Back up lights
    Electric Fan
    Coil
    Turn Signal
    Some of these will be swaped for other uses. Each wire is printed up with its use and the loom is seperated into various groups to aid installation
    Click image for larger version Name:	IMG_0921.jpg Views:	34 Size:	275.6 KB ID:	48069
    Click image for larger version Name:	IMG_0922.jpg Views:	30 Size:	197.5 KB ID:	48070
    Fabricated a bracket from stainless to mount the fuse board vertically on the gearbox tunnel
    Click image for larger version Name:	IMG_0919.jpg Views:	27 Size:	119.3 KB ID:	48071
    Click image for larger version Name:	IMG_0920.jpg Views:	30 Size:	188.7 KB ID:	48072
  13. #53
    May 2010
    North Yorkshire
    213
    17
    Designed a bracket for the clutch and brake reservoirs as i cant find an off the shelf one i like the look of. Plan is to fit it on top to the bulkhead on the n/s
    Click image for larger version Name:	CylinderResevoirLayout.jpg Views:	27 Size:	34.4 KB ID:	48079
    Designed it on Solidworks from rough measurements. this allows me to print out a flat pattern of the part. with a bit of cutting and sellotaping came up with this blue peter special to test the fit
    Click image for larger version Name:	IMG_0914-1.jpg Views:	26 Size:	112.3 KB ID:	48080
    After trying it this afternoon a few of the dimensions do need changing to get the fit spot on. will have another go tomorrow then get it sent off to the laser cutters for manufacture
  14. #54
    May 2010
    North Yorkshire
    213
    17
    Had a bit of a shuffle about in the workshop to get another car in
    Click image for larger version Name:	IMG_0923.JPG Views:	31 Size:	1.26 MB ID:	48123
  15. #55
    May 2010
    North Yorkshire
    213
    17
    Been working away most of this week so had very little chance to get anything done
    Engine mounts are nearly finished though, just need gusseting
    Click image for larger version Name:	IMG_0929.jpg Views:	44 Size:	171.2 KB ID:	48225
    Click image for larger version Name:	IMG_0930.jpg Views:	44 Size:	222.9 KB ID:	48226
  16. #56
    Nov 2003
    Wirral UK
    6,740
    257
    Tidy welding
  17. #57
    May 2008
    Desborough,northants
    20
    Quote Originally Posted by flinny1986 View Post
    Attachment 48225
    Attachment 48226
    Liking these engine mounts.Look like the ones RetroFord made for his MK2 escort drag car
  18. #58
    May 2010
    North Yorkshire
    213
    17
    Found some pictures of the retroford ones, going to have to change the way im gussetting mine to keep them different
    Im afraid i cant take credit for that welding, a guy from work has done it for me.. he builds his own choppers in his spare time. all his work is second to none. will get some pictures of a few bikes
  19. #59
    Jul 2006
    bristol
    10,882
    892
    Looking good bud got all this stuff to do on mine so watching closely.
    Ive started A thread now too.
  20. #60
    May 2010
    North Yorkshire
    213
    17
    Cheers Trig, i have been having a look at your build. loving moving the motor right back, ignore the haters. it will be a weapon when its done
    Bit of a digression, here are a could of bikes that my welder has in his collection
    Click image for larger version Name:	IMG_0932.jpg Views:	28 Size:	173.3 KB ID:	48316
    Current bike he built with 1964 Harley Sportster engine (For Sale)
    Click image for larger version Name:	IMG_0933.jpg Views:	23 Size:	154.1 KB ID:	48317
    Current work in progress, Custom with 750 twin motor
    ..........Back to the escort
    Degined a tunnel extension to weld on which should be ready by the weekend. had been struggling to find a sensible gear gaiter. finally opted for a fiesta mk6 item and got one cheap off ebay
    Click image for larger version Name:	IMG_0935.jpg Views:	26 Size:	181.0 KB ID:	48318
    Will have to make an insert to go in the top and some kind of plate to tie it down to the tunnel.
    Also ordered some Powerflex universal bushed to crate a gearbox mount. Not really got a plan for it yet so hoping that getting some parts together will give me some inspiration.
    Finally ordered a new waterpump for the motor, the origional one was not looking in brilliant condition. Was nearly tempted to go down the route of an electric pump which most of the duratec installs seem to use, but going to stick with the mechanically driven one and keep it simple.
  21. #61
    TURBOSPORT SPONSOR Turbosport Sponsor brafferton's Avatar
    Apr 2007
    york
    70
    207
    Finally got some photos of the tunnel
    Tank platform welded in and carbon fibre spare wheel tray trimmed to fit
    Boot catches in place with some 3M carbon fibre trims
    ..........this was a bit of an experiment!happy with how it has panned out so it can stay! was a bit concerned about how ealisy the sliders opened on the front windows so got hold of some m5 spring loaded plungers from a work supplier and made some plates to mount them in....drilled the bottom of the slider at 25mm increments, this allows 10 positions for the windows to be positivly held at
    Im the guy that made your polycarb windows. Like the look of the locking system you made. Hope you dont mind if I pop next door and have a look.
    Stuart.
    Airedale Race Components
    01423 360456
    http://www.raceplastics.com
  22. #62
    May 2010
    North Yorkshire
    213
    17
    Hi Stuart. Was hoping to bump into you at some point. Firstly, thank you for sorting me out with the rest of the windows. Top job. Feel free to pop around have a look whenever you like. Im up there some evenings and most weekends. The window catch plates work really well, they are only a prototype at the moment though. I have the finished parts drawn up, just need to get them onto the laser cutter. They are a smaller shape with nice radii on the corners.
    They will look like this
    Click image for larger version Name:	window catch.JPG Views:	31 Size:	84.7 KB ID:	48373
    I have PM'd you my contact number
  23. #63
    May 2010
    North Yorkshire
    213
    17
    Made an aluminium insert for the top of the fiesta gear gaiter this morning. Still undecided about the bottom yet, will need to wait until i get the tunel extension made at the weekend
    Click image for larger version Name:	IMG_0941.jpg Views:	24 Size:	233.7 KB ID:	48374
    Click image for larger version Name:	IMG_0942.jpg Views:	25 Size:	229.8 KB ID:	48375
    Also got 2 pairs of the Powerfox bushes for the gearbox mount
    Click image for larger version Name:	IMG_0940.jpg Views:	22 Size:	144.3 KB ID:	48376
  24. #64
    May 2010
    North Yorkshire
    213
    17
    Made some good progress tonight after a trip to collect some parts today.
    Gearbox tunnel extension and brake/clutch cylinder reservoir bracket
    Click image for larger version Name:	IMG_0943.jpg Views:	44 Size:	150.3 KB ID:	48401
    Gusset plates for the under side of the A pillars
    Click image for larger version Name:	IMG_0944.jpg Views:	26 Size:	153.9 KB ID:	48402
    Gussets to finish off the engine mounts
    Click image for larger version Name:	IMG_0945.jpg Views:	22 Size:	145.4 KB ID:	48403
    Still not quite worked out what im doing with the gearbox mount, made some stainless housings for the bushes to get me one step closer to a solution
    Click image for larger version Name:	IMG_0946.jpg Views:	23 Size:	143.6 KB ID:	48404
    Went to the lock up to check the fit of all the parts. By chance had works capasitor discharge stud welder in the van so used it to get the mountings on for the reservior bracket and a few earth points around the car. Worked a dream, they are impossible to neck off when applied right.
    Click image for larger version Name:	IMG_0947.jpg Views:	25 Size:	251.1 KB ID:	48405
    Click image for larger version Name:	IMG_0948.jpg Views:	21 Size:	193.2 KB ID:	48406
    Click image for larger version Name:	IMG_0951.jpg Views:	24 Size:	170.0 KB ID:	48407
    Finally........ got all the rollcage plates trimmed and stuck into position ready for welding next week. (The ratchet strap is the current gearbox mount!!!)
    Click image for larger version Name:	IMG_0952.jpg Views:	25 Size:	233.4 KB ID:	48408
  25. #65
    Nov 2003
    Wirral UK
    6,740
    257
    Looking really good there, I love that stud welder too
  26. #66
    May 2010
    North Yorkshire
    213
    17
    Thanks it really is a neat way of fastening things down. No more fiddling around up the back of panels trying to find nuts
    been working away in east yorkshire all weekend and got a bit of a flier today so called in unannounced to Ralloy on the way home to get a strut brace and some window seals.
    Click image for larger version Name:	IMG_0961.jpg Views:	29 Size:	183.9 KB ID:	48530
    They had non of these alloystrut braces made when i arrived but by the time i had got settled up Roy had welded one for me. Top quality and top service all round
    Whilst there i spotted a batch of these on the shelf and had to get one.....
    Click image for larger version Name:	IMG_0960.jpg Views:	25 Size:	186.1 KB ID:	48531
    Buy the looks of things, the normal way to mount these is on a mild steel base which is welded into the boot floor......... but i think i will just break out the stud welder again
  27. #67
    May 2010
    North Yorkshire
    213
    17
    Quick update, machined the tunnel extension out to take the gear gaiter tonight. Test ftted it and it looks good. Had to put getting the welding off for another week due to work commitments but its giving me chance to get a few more bits organised.
    Click image for larger version Name:	IMG_0964.jpg Views:	21 Size:	148.5 KB ID:	48569
  28. #68
    Jul 2006
    bristol
    10,882
    892
    Some lovely looking bits there bud
  29. #69
    May 2010
    North Yorkshire
    213
    17
    Cheers Trig. Had a lack of updates due to loss of my iphone for taking pictures. Got myself a new iphone 4s at beginning of the week! Already smashed the ba***rd! its still a runner though so managed to get a few pictures.
    Got a remote oil filter housing, wont say where from as its not there there fault but the quality of it was crap to be fair. Its a Mocal one, for a 3/4"UNF filter, 1/2"Bsp fittings. Sharp edges and flash from themanufacturing and saw marks where it has been cut off from the cast. after about an hour attaching it with files and emery paper got it loking half nice.
    Banged a couple of studs onto the n/s inner wing to mount it. think i will get it powdercoated to finish it off
    Click image for larger version Name:	IMG_0973.JPG Views:	25 Size:	1.73 MB ID:	48722
    Stud elded into the boot to mount the dry sump tank too. this sat on 2 different levels so have got one side on some ally spacers
    Click image for larger version Name:	IMG_0974.JPG Views:	28 Size:	1.82 MB ID:	48723
  30. #70
    May 2010
    North Yorkshire
    213
    17
    Click image for larger version Name:	IMG_0997.JPG Views:	21 Size:	3.24 MB ID:	48760
  31. #71
    May 2010
    North Yorkshire
    213
    17
    Fabrication of the engine mounts completed today. Thrown a bit of primer at them, think i will get them powder coated before the final assembly
    Click image for larger version Name:	IMG_1001.JPG Views:	29 Size:	1.96 MB ID:	48795
  32. #72
    Nov 2003
    Wirral UK
    6,740
    257
    Tidy!
  33. #73
    Jul 2006
    bristol
    10,882
    892
    I'm lovin the engine mounts.
    Did you cut your own engine plates?
    Do you think you could cut me some Please???
  34. #74
    Jan 2011
    Sarf Rugeley
    584
    32
    Great project. Youve set the standard there. Those engine mounts are a work of art.
  35. #75
    May 2010
    North Yorkshire
    213
    17
    Thanks for the comments guys. Next step is the gearbox mount then can get the motor back out.
    I use a company near york for my cutting. use the day in day out through work so they cost next to nothing. when your ready for them get the measured up to suit and give me a shout and i will draw them up and send them off for you.
    got the 8mm engine mount plates drawn up too so if you need a set cutting give me a shout
  36. #76
    Jul 2006
    bristol
    10,882
    892
    It's just the engine plates I'm after bud I got a chassis mount from another engine install there's a guy on eBay selling just the plates for £20.
  37. #77
    May 2010
    North Yorkshire
    213
    17
    Will get you a price sorted tomorrow when im back in the workshop mate. Will get a few sets cut to keep the price as low possible. Will stick the rest on ebay
  38. The Following User Says Thank You to flinny1986 For This Useful Post:
  39. #78
    May 2010
    North Yorkshire
    213
    17
    Another great weekend working on the car. Mainly fabrication
    Lifted the motor and box back out on thursday to free up some room for the weekend work and bolted the engine mounts on
    Click image for larger version Name:	IMG_1011.jpg Views:	26 Size:	227.1 KB ID:	48923
    Firstly, Had not got around to designing any plates for gearbox mounts. Gave in in the end and just made them up as i went along. The only mild steel material i could find that would be suitable was this piece of rsj! So got busy with the grinder and cut the web out
    Click image for larger version Name:	IMG_1005.jpg Views:	23 Size:	296.2 KB ID:	48919
    Click image for larger version Name:	IMG_1006.JPG Views:	22 Size:	2.97 MB ID:	48920
    Welded them into the tunnel and they look spot on.
    Click image for larger version Name:	IMG_1015.jpg Views:	19 Size:	173.2 KB ID:	48921
    Strut brace brackets welded on
    Click image for larger version Name:	IMG_1017.jpg Views:	23 Size:	138.1 KB ID:	48922
    All the roll cage plate welded in and primed
    Click image for larger version Name:	IMG_1016.jpg Views:	20 Size:	186.0 KB ID:	48924
    Click image for larger version Name:	IMG_1013.jpg Views:	19 Size:	140.7 KB ID:	48925
    Click image for larger version Name:	IMG_1012.jpg Views:	21 Size:	188.3 KB ID:	48926
    Tunnel extension welded in ready for paint. also studs on to mount the fuse block
    Click image for larger version Name:	IMG_1014.jpg Views:	19 Size:	231.9 KB ID:	48927
    Chuffed to bits with the progress. really feels like its in motion again
    Need to get the mig welder back out to finish off the o/s chassis engine mount and the eye bolt plates for the harnesses then its ready for paint
    Click image for larger version Name:	IMG_1010.jpg Views:	19 Size:	209.9 KB ID:	48928
    Click image for larger version Name:	IMG_1018.jpg Views:	20 Size:	202.2 KB ID:	48929
  40. #79
    Jul 2006
    bristol
    10,882
    892
    Fair play bud cracking job.
  41. #80
    Nov 2003
    Wirral UK
    6,740
    257
    Nice work mate
Tags for this Thread
