Page 8 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 281 to 320 of 376
Thread: Mk2 Duratec Escort
  1. #281
    Sep 2005
    Herts
    983
    Re: Mk2 Duratec Escort
    Hi Mark
    I've had that with the rear crank seal before, you've got to be a little bit more generous with the sealer around the rear where the seal sits. What sealer are you using? I've had the best results with Loctite 5910 it's the black OE stuff, usually get it from halfords, it comes in a large toothpaste style tube.
    Matt
  2. The Following User Says Thank You to cossie matt For This Useful Post:
  3. #282
    May 2010
    North Yorkshire
    213
    17
    Thanks again lads
    Quote Originally Posted by FrEdOoOo View Post
    Top JOb!!!
    btw: what tyres have you at front?
    Had a look last night mate, they are Toyo Proxes R888. Not sure they are any good or not, they came on the rims
    Quote Originally Posted by muckerbarry View Post
    Brilliant work Mark, jaw dropping in fact.
    Just one question, the fuel pump brackets that you've had water jet cut, how do you smooth them before they get anodized? I plan to have some parts cut myself and i was wondering how i was going to smooth out the little ridges form the water jet.
    Thanks,
    Alan.
    Alan, was a bit of a learning curve polishing the aluminium. The finish around the outside in this picture is the finish i had to get it to.......
    Used rotary flap wheels in a die grinder to flatten the cut surface..
    http://www.ebay.co.uk/sch/i.html?_od...wheel&_sacat=0
    Then used one of the cheapo felt polishing kits off ebay....
    Cost about £13
    http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
    Then to polish up the flat surfaces I used the polish from the other kit and a couple of these
    http://www.ebay.co.uk/sch/i.html?_od...115mm&_sacat=0
    It was a long progress but definitely worth it, the closer to mirror finish you can get the metal the deeper the colour will be when they anodize it.
    Couple of tips.........use as much of the polishing compound as you can, its easy to let the felts dry out and do it somewhere you don't care to much about. I ended up black from head to toe!
    Quote Originally Posted by Alan G View Post
    Nice work!
    Can I ask where you got the bracket to hold the wheel speed sensor??
    You have PM regarding bracket mate
    Quote Originally Posted by cossie matt View Post
    Hi Mark
    Matt
    Thanks Matt, that was not the one I used but it looks similar stuff. If this fails I will give it a go. Thanks. It was that area you had a problem with by the sounds of it, where the sump meets the bottom of the seal housing? Its got more than should be enough sealer in there this time! I have built it back up and left it over night to cure so will fill it back up with oil tonight and have a look.
    Cheers mate
    ​enquiries@flintec-eng.co.uk
  4. #283
    Jun 2006
    kilkenny, ireland
    519
    thanks mark, i was afraid you were going to say you hand polished them!
    alan.
  5. #284
    May 2010
    North Yorkshire
    213
    17
    Slowly getting it put back together. Need to get the flywheel back on tomorrow night then get it back to my unit.
  6. #285
    Sep 2008
    west yorks
    116
    Mk2 Duratec Escort
    Pm sent re cam cover
  7. #286
    May 2010
    North Yorkshire
    213
    17
    Cam cover is done
  8. #287
    Mar 2006
    In the garage getting cold
    1,448
    31
    Cam cover looks the buissness and the perfect topping on the engine to this fantastic build
  9. The Following User Says Thank You to 105Ian For This Useful Post:
  10. #288
    Pit Crew gorilla1q's Avatar
    May 2009
    Cheshire
    1,345
    67
    That cam cover
    When I grow up I will have a MK1 Escort
    I must be all growed up now then and paying for it!
  11. #289
    Mar 2004
    Barking Essex
    9,033
    262
    Mk2 Duratec Escort
    Awesome!!!
    Old skool forever
    Just don`t tell the wife
    how much it really costs!
  12. #290
    Dec 2007
    Dubai
    1,678
    29
    Looks suitably hard core, lovely job
    www.gulfpetrolheads.com
  13. #291
    Nov 2003
    Wirral UK
    6,740
    257
    Stunning, simply stunning
    http://escort.accelerator.org
  14. #292
    May 2010
    North Yorkshire
    213
    17
    Thanks lads, could not be happier with the cam cover.
    Been on tidying up a few bits of the build this week whilst waiting for the doors, boot and bonnet to come back from paint. Fostek are well on with the axle which only really leaves 2 big jobs, brakes and clutch.
    Got the exhaust finished off. Had a read on a few forums and apparently this is about as good as it gets for painting exhausts.........
  15. #293
    Spanner Monkey FrEdOoOo's Avatar
    Mar 2009
    Portugal
    384
    25
    That Cam Cover
  16. #294
    Jun 2004
    Yarm (Teesside)
    64
    Stunning work
  17. #295
    Jun 2007
    Whitley Bay
    3,437
    81
    You need to tool that cam cover matey its class
    Screaming 1300 mexico rep
  18. #296
    Formerly harrier mk2 Decade Plus User Fridgeman's Avatar
    Jun 2007
    Derby, United Kingdom
    2,529
    151
    very nice car and build mate.
    EVERY DAY,S A LEARNING DAY
  19. #297
    Mechanic roosie's Avatar
    Jan 2003
    Brandon Norfolk
    895
    i like the akrapovic springs, how are the eyes made on that exhaust are they bent washers welded on pipe?
  20. #298
    May 2010
    North Yorkshire
    213
    17
    Thanks again lads. Hopefully it will all be completed by the end of next month
    Quote Originally Posted by roosie View Post
    I got some tabs laser cut out of 3mm steel but must have sent them off to one of my customers in the bottom of a bag of their parts never to be seen again!
    In the end as you have spotted these are M10 washers, stuck them over the vice and gave them a good crack with a chisel down the middle. Also ground a bit of a flat on them so I had a bit more weld area.
    Small amount of progress this weekend. Added a changeover relay to the windscreen wiper circuit so the park function works, and fit the polycarbs to the rears
    Put painting the rest of the panels on hold again as I have chance of a fiberglass boot lid later on in the week.
  21. #299
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Quote Originally Posted by flinny1986 View Post
    They're in the glovebox of my car! Well, 3 of them are, I think my daughter ate one of them.
  22. #300
    May 2010
    North Yorkshire
    213
    17
    Cant accept any liability there, they were not designed to be fit for human consumption!
  23. #301
    Mar 2013
    Kent
    32
    81
    I was just about to say the same thing about the Akrapovic springs!
  24. #302
    May 2010
    North Yorkshire
    213
    17
    First of all apologies for the lack of updates, life is hectic at the moment. Jumped ship at work and have set up on my own so that has taken up 95% of my time. The other 5% I have managed to crack on getting the car almost completed.
    Massive thanks to Tom and John at Fostek for getting the axle built, it fits beautifully and is an absolute masterpiece........
    Fully floating Atlas, Gripper diff, 4.6CWP, lightweight hubs, Ap handbrake calipers
    Click image for larger version Name:	photo4_zps8bd88276.jpg Views:	1016 Size:	100.8 KB ID:	64481
    Click image for larger version Name:	photo5_zpsec333790.jpg Views:	1016 Size:	65.1 KB ID:	64482
    Click image for larger version Name:	photo2_zps8fdc52ef.jpg Views:	1015 Size:	80.9 KB ID:	64483
    Click image for larger version Name:	photo1_zps070b91b7.jpg Views:	1014 Size:	73.2 KB ID:	64484
    All the brakes are now pipe up, wiring complete, though my master switch seems to have given up tonight I have got an Super2000 clutch sorted out.
    Jobs left to do..............
    Finish modifying bell housing for quick release gearbox (will get some pictures up at the weekend)
    bur a release bearing
    fit clutch and box
    buy a prop
    fit front screen once its had a quick blast around the yard and i an certain i can bolt the dash down
    doors and panels to refit
    passenger seat to buy and fit
    dry cell battery
    2 weeks...............
    Click image for larger version Name:	photo11_zps109fd662.jpg Views:	1015 Size:	92.9 KB ID:	64485
  25. #303
    Mechanic Matt75's Avatar
    Mar 2011
    Melbourne
    797
    Great stuff as always. Is that a breather tube in the first pic above?
    Not long now....
    Cheers,
    Matt
  26. #304
    Nov 2003
    Wirral UK
    6,740
    257
    Car porn, pure and simple
  27. #305
    FOSSIE's Avatar
    Oct 2004
    NEWCASTLE
    1,591
    Quote Originally Posted by Matt75 View Post
    Yes the breather just vents the axle casing to atmosphere, stops it pressurising when it heats up/cools down. Pipe just stops water getting in...
  28. #306
    Jun 2013
    Seaford
    66
    I am doing the same conversion with a Raceline Duratec, i used world cup x member and retro ford mounts, all worked well. Got an oil filter adaptor from Dunnell who do one for dry sumps as well as wet. I have used a Mazda MX 5 gearbox which i have had varying comments about. Wiring the ECU is next on the list and then should be ready to go.
  29. #307
    East Sussex
    58
    5,023
    Quote Originally Posted by riggiesdad View Post
    Get some pics up then John.
  30. #308
    I support TS Decade Plus User
    Jan 2007
    Dorset
    1,232
    168
    Looking great! Can't beat frozen white
    Lovely axle as well, love the unique details like the lightweight hubs and the lazer cut "Fostek" logos - Toms a great guy, very helpfully indeed.
  31. #309
    Jan 2006
    N.IRELAND
    47
    I've just read the thread from start to finish , an unbelievable standard of work , all the one off stuff is out of this world . That is a mighty car !
  32. The Following User Says Thank You to philipmax For This Useful Post:
  33. #310
    May 2010
    North Yorkshire
    213
    17
    Thanks lads. Seriously struggling to find time to get this thing finished off at the moment. I think a couple of good days and it will be done.
  34. #311
    Aug 2013
    donegal,lreland
    47
    23
    fair play to ya lad great work
  35. #312
    May 2010
    North Yorkshire
    213
    17
    Thanks again lads. Bit of an update...
    Had very little time and even less motivation over the last couple of weeks but I have managed to get a few of the jobs struck off.
    Quick release bosses fabricated and fitted into the bell housing.
    Getting the spacing set for the clutch release bearing has been the most frustrating part of this build so far! Basically, with the combination of AP clutch and release bearing I am running there was no room for a spacer in the back of the bell housing. I was planning to rely on the spacer as an adapter to convert the mismatched hole positions on bell housing and release bearing.
    I ended up modifying the bell housing with and adapter sleeve which would then locate the release bearing concentrically, and had to drill and tap the back of the bell housing to fasten the two components together.
    Bit of a crap photo but its in!
    This is the last major component of the build
    Prop is in now, brakes are bled up, clutch is bled up.......................and it drives
    The video we took was poor so will get one up asap. Got a few small mechanical bits to do yet, and need to re fit doors, boot and bonnet, but going to get the thing booked in for an MOT before the end of the month.
  36. #313
    Mar 2006
    1,448
    31
    Great to hear you are so close to finishing it now , and hopefully that first drive will give you the boost to get all those last jobs done
  37. #314
    Jun 2007
    2,529
    151
    great car, luvley spec.
  38. #315
    Mar 2012
    Aberdeen
    21
    PM me if you are looking to get support for another cam cover.
  39. #316
    Oct 2008
    whitley bay
    2,436
    89
    Hello mate
    Would you be able to do some more seat mounts the same as yours?
    Hexham and District Motorclub
  40. #317
    Sep 2008
    west yorks
    116
    Mk2 Duratec Escort
    Cant believe youve"jumped ship" with access to all the machines/materials!
  41. #318
    May 2010
    North Yorkshire
    213
    17
    Quote Originally Posted by nigelonich View Post
    Hello mate
    PM's on their way lads
    Quote Originally Posted by billy sollocks View Post
    Was a big decision to make Lee trust me! After 11 years at the company and an ever increasing work load ......................... anyway! I am flat out on all sorts of design projects at the moment and in the process of dotting i's and crossing t's on building a brand new CNC workshop. Watch this space.
    Will also be looking to becoming a Turbosport sponsor if anyone knows how to go about that???
  42. #319
    Oct 2008
    whitley bay
    2,436
    89
    Easy enough graham will sort it for you thanks for the response
  43. #320
    May 2010
    North Yorkshire
    213
    17
    After pretty much an all nighter on Friday got the car about MOT ready, leaving just a couple of daft little jobs for Saturday morning, number plate lights to wire, wash jets to fit into bonnet, mirror to mount.
    Got all the jobs finished in good time Saturday morning, 10 minutes before setting off for test thought I best give it a good blast up the road as its only ever moved a couple of hundred yard under its own steam. would it start....NO
    Plenty of fuel, power to ecu, stook a spare plug into each lead and all sparking, could not find a plug socket and a normal deep one would not fit through the cam cover! So cam cover had to come off to get the plugs out, and they were in need of a good clean. I had been messing on with the fuel pressre reg the day before and it must have been running way over pressure. Re fittled the gauge and dialed it back into to 2.9bar, with the clean plugs it fired straight up.
    Mad rush then to the test centre, only to be told he could not test it without a chassis number permanently somewhere on the shell So sped off in a courtesy car to the workshop and dremmeled it into a bit of tin, then back to the garage to rivet it on!
    Anyway it passed!! Only comment he did make was there it a bit of wear in on the drumsticks so its getting a new HD rack when it gets its geometry set up on tomorrow.
    Drives really well though, pulls like an train right through the range in every gear. Will look into getting it on the rollers soon but to say its only got a base map in it there are no noticeable flat spots, real credit to Steve at SBD.
    I have a few things on the snagging list, Mainly fit a catch tank for the dry sump instead of an empty Volvic bottle, get another seat as I using a borrowed one in the passenger side and wire up the heated screen.
Tags for this Thread
