Hi all,
I am half way through my auto to type 9 conversion on my mk2 1600 Ghia and have come up with an issue. The auto box, torque convertor etc has been removed and i just have the crank palm to fit my crossflow manual flywheel to. The only issue is, is the hole in the centre of the flywheel is 45mm and the spigot on the rear of the crank palm is 35mm, so there is a circumference of 10mm gap meaning the flywheel cannot centralize itself. The hole in the old torque convertor plate is correct for the crank but it is still smaller than my flywheel centre. Is there anyway around this?
Thanks, Neil
