711m 6015 DA need some background to this block
I would appreciate some background to 6015 DA engine blocks . Thanks
Re: 711m 6015 DA need some background to this block
As far as I'm aware there are no "711m 6015 DA" blocks, only 711m 6015 BA.
There is a 681M 6015 DA - that's a fairly early 1600 crossflow with small cam follower bores and round mains caps. Came out late 1967/early 1968.
my mistake yes this e block is a 681f 6015 da with square caps dip stick on the right if facing the engine.
"DA" with square caps? Never seen that before - I've only ever seen "JA" with square caps on crossflows.
Are you sure it's a 1600 block and not a 1500?
