Hi, I've found an Excel sheet which was created (not by me) to compare camshaft profiles. So i measured out some pinto cams I had lying around.
Blue line is a stock 2000 / 1600 GT pinto cam
Green is Kent FR 32
Orange is Crane 22803-2
Brown is Piper HR 300 (that's what is marked on the back of the cam anyway, old 80s profile I think)
Column on the left = valve lift in Millimeters
Bottom column = crankshaft degrees
Auslass = Exhaust
Einlass = Intake
OT = TDC
Kolben = Piston
Maybe it`s useful for anyone. All cams were measured at Standard .20/.25 valve clearance in the same head which had the valve seats slightly recut so valve lift is a bit down due to altered rocker geometry.
