I need to raise some funds so am looking to sell a complete cosworth set up I have. There is everything needed to complete the swap in to any car.
2wd std cosworth engine (205 block)
Std bore, no real wear
Head measures 138.8mm
Inlet with injectors, throttle body and exhaust manifold with turbo.
ECU, loom and coil.
T5 gearbox, clutch fork
Clutch and flywheel
New in the box airtec rad and intercooler for mk1/mk2 escort, will fit other cars too.
Would be perfect for anyone wanting to fit a cosworth turbo in to an old ford. When I bought it I was told it was a good runner. I had planned to removed the sump to check the shells and fit it in my 100e as it was, but unfortunately I now need them money more than the engine in my car.
I would like £6000 for everything. Not looking to split unless I can find buyers for all parts prior.
Cheers joe 07989814096
