Moderator+
RWD 4AGE bits (WHY)
Looking for the following escort/4age 16v bits;
- Large port Twin Weber manifold, ideally to suit 40's
- Exhaust manifold
Potentially open to other 'go-faster' bits depending on what you have
Re: RWD 4AGE bits (WHY)
Still got 4 steal conrods available for this engine. 100€ + transport and all yours.
At one moment we could not buy single sets anymore to get dealer prices, only 5 sets in one order and this one has never made it into an engine. Dry stored for approx 8 years.
Moderator+
I'm ok for internals thanks mate but will keep you in mind if the plan changes.
Were the rods for 40 or 42mm crank?
For the late 7 rib engine, so I guess it was 42mm (and thicker piston pin???). If you can use them I'll check.
Moderator+
Mine's an early 40mm crank so not much use.
Thanks anyway
