Hi got my Duratec in a Mk2 escort running Mbe wire harness and tbs was running ok now it won’t start
tried crank sensor,plugs,separate battery for for ecu
anyone no what else a can try all new stuff
al
al
Have you got a good spark at the plugs?
Hi Al,
Do you have easimap to see that feedback the ECU is getting from the sensors?
If your not getting any spark I'd guess the ECU isnt seeing a crank signal, is the sensor aligned properly?
Do you have power at the coils / coil pack?
Simon
Hi ordered the connector cables to link pc tried new sensor plug coils got power fuel ok
Was running then 2 days later just turning over
