Results 1 to 11 of 11
Thread: 2.1 pinto
    Mar 2017
    Fife,Scotland
    27
    10
    2.1 pinto
    Looking for rough guide to what bhp I would achieve with v6 pistons 205 block with twin 45s?
    possibly stage 3 head
    tia
    adam
    25,110
    Re: 2.1 pinto
    anything from 130 to 180bhp!
    Mar 2017
    Fife,Scotland
    27
    10
    Re: 2.1 pinto
    Do I need to deck the block when I use the v6 pistons?
    25,110
    Re: 2.1 pinto
    depends on what con rods you use, if you use pinto ones yes
    Mar 2017
    Fife,Scotland
    27
    10
    Re: 2.1 pinto
    Probably will just use pinto,ones only looking to achieve 150/160bhp
    25,110
    Re: 2.1 pinto
    you will also need to narrow the con rod small ends
    Mar 2017
    Fife,Scotland
    27
    10
    Re: 2.1 pinto
    I’m beginning to wonder if I’m cheaper just going for The correct rods and pistons for the 2.1 rather than all the farthing about not sure if it will work out the same price when taking all the machining into consideration
    9,200
    Re: 2.1 pinto
    just forget 2.1 - its s.london facebook BS lol
    edit - but say its a 2.1 when selling it - thats compulsory
    2,656
    267
    Re: 2.1 pinto
    What size V6 pistons are you using? You'll need to use 93.5mm to get a true 2100cc that'll actually give you just over at 2113cc. You wont ever get another rebuild should you need one out of that block bored to 93.5mm. 93mm will give you 2090cc and 92.5mm will give you 2068cc.
    Mines got 93.5mm pistons and I won't ever bore another block to 93.5mm.
    25,110
    Re: 2.1 pinto
    my advise is just to rebore to whatever size the block needs to make it good again unless you are trying for really big cc with a stroker crank, power gain from boring to 2.1 will be minimal
    Re: 2.1 pinto
    I have been there done that and all the rest of it with a 93mm bore both with Pinto and NA Cosworth engines many years ago. The hassle we had with getting the correct pistons and head gaskets was unbelievable back then and it wasn't worth what little bit of extra power was gained, if any. + 40 thou pistons should be plenty for your rebuild. Leave 93mm pistons where they belong back in the dark ages!
  12. The Following User Says Thank You to Forest_rallying For This Useful Post:
Tags for this Thread
