Results 1 to 6 of 6
Thread: St170 starter motor
    Sep 2019
    London
    22
    St170 starter motor
    Fitting an st170 into a sierra..2.0 zetec flywheel refilled to take pinto clutch mating to a type 9
    I was planning to use the original starter motor is this possible if not could someone let me know what I can do
    3,242
    Re: St170 starter motor
    Don't think it is! Compare yours with those Dave @ Retroford sells for his conversion? Also the 2.0L flywheel is not something to use if you want anything like performance - it weighs a ton compared to the 1.8 version!
    Sep 2019
    London
    22
    I have refilled and cnc down to lose weight should be fine... do you know what starter is needed
    3,242
    Quote Originally Posted by Ricey1234 View Post
    As I said above . . . . https://www.retroford.co.uk/product/...er-motor-z020/
    2,660
    268
    Try a mk1 rs2000 starter motor in it.
    Holland
    32
    252
    32
    with zetec flywheel you need a DOHC I4 starter
