St170 clutch
I'm building an st170 into a sierra and was wondering what clutch to use I'm using zetec flywheel refilled to take a pinto pressure plate... will a standard clutch be ok to use for road use or would it be better with a paddle clutch or uprated one
I'm only running a standard engine on bike carb with vvt control so should be about 170 bhp
Re: St170 clutch
I would put a paddle clutch plate in.
As diameter is not that big, just to be sure
