Page 8 of 16 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 281 to 320 of 630
Thread: Duratec powered vintage Sprint car
  1. #281
    Jul 2006
    bristol
    10,882
    892
    Re: Duratec powered vintage Sprint car
    Good to see a bit of progress buddy next day is on the 13th sept bud
  2. #282
    Mechanic Blackvette59's Avatar
    Sep 2011
    Wales
    72
    787
    179
    .....Trig.....thats my anniversary.....don't think I would be able to convince her a day out in Castle Coombe would be a good way to celebrate.....I'll get to one of your gig's if its the last thing I do.. (hey.... Trigs Gigs....could be on to something here !!! )
  3. The Following User Says Thank You to Blackvette59 For This Useful Post:
  4. #283
    Sep 2011
    Wales
    72
    787
    179
  5. #284
    Sep 2011
    Wales
    72
    787
    179
    .....Then Mac Miller threw a spanner in the mix......what can you say ?
  6. #285
    Jan 2011
    clacton essex
    1,731
    70
    so right
    as you were,
  7. #286
    Sep 2011
    Wales
    72
    787
    179
    .....this year has flown,and to be honest,not much progress made.Not going away until Amelia Island in March,so I'll have a chance to get some work done.I have managed to a a few jobs....modified the engine mount rubbers to fit through the frame,got a set of knock off's that had to be refurbished and repolished(a dirty job)these are on the car and look OK.Sorted out my accelerator and injection linkage,and have re visited the brake system.Going to use two cylinders instead of the single I was planning on using,with balance bar and check valves.All the body panels are now finished and ready for paint,and thats where I'm at.....now I never do lists until its time to bust it all apart for paint and detail,but I'm getting old,so the list has began...
  8. #287
    Sep 2011
    Wales
    72
    787
    179
    ...here are the ''knock offs''....
  9. #288
    Sep 2011
    Wales
    72
    787
    179
    .....right...need to finish the tails chassis....got the tube...got the bender....hope this isn't too hard a job.....thats a big tail
  10. #289
    Sep 2011
    Wales
    72
    787
    179
    .....this is what I am aiming for.....but the two top tubes will be extended to protect the fuel tank.....
  11. The Following User Says Thank You to Blackvette59 For This Useful Post:
  12. #290
    Jul 2006
    bristol
    10,882
    892
    About you did some work.
  13. #291
    Sep 2011
    Wales
    72
    787
    179
    ....Trig...you are right.....
  14. #292
    Jul 2006
    bristol
    10,882
    892
    Lol I can't shout too loud I'm as bad but may have a little something to work on next year.
  15. #293
    Sep 2011
    Wales
    72
    787
    179
    ......no hints mate??????
  16. #294
    Jul 2006
    bristol
    10,882
    892
    Im a escort nut
  17. #295
    Sep 2011
    Wales
    72
    787
    179
    .....what was I thinking ??? ..... thought you might have come over to my dark side.....
  18. #296
    Jul 2006
    bristol
    10,882
    892
    Maybe when I'm retired I'll have the time to build a hot rod of some sort.
    Always liked mk1 zeyhers but would do new chassis and fit supra engine.
  19. #297
    Sep 2011
    Wales
    72
    787
    179
    ....now thats going to be a long way in the future.....
  20. #298
    Sep 2011
    Wales
    72
    787
    179
    ....bending tube is not that easy.....but after a couple of fails got into it.....I found it better to make bends in smaller sections....trying to make double bends is hard.Most of the progress this year has not been that noteable,and I found myself going over parts that had already been sorted (or so I thought).The clutch pedal works well (at least on the bench)...the handbrake cylinder is ready to mount....and the accelerator mount and pedal sorted.The brake pedal and cylinder mount is still on the '' drawing board''...got all the brake lines and fittings,and reworked the engine mounts so they go through the frame.The grade 5 bolts will have their heads cut off,threaded to take nylocks,and welded to the rubber plates.All the fuel lines are sorted,and Alex from Torques is going to pop down to help plumb swirl pots,filters and pumps.....I have cut the 3mm firewall,and hope to get this bent and installed this week...
  21. #299
    Jul 2006
    bristol
    10,882
    892
    progress
  22. #300
    Jan 2011
    clacton essex
    1,731
    70
    them pedals are a piece of art buddy,
  23. #301
    Sep 2011
    Wales
    72
    787
    179
    ....Trig...a little.....I've been studying your fuel system and I think it will fit in the tail,as long as I can get a swirl pot as small as yours......rwd,now if only they work....
  24. #302
    Jul 2006
    bristol
    10,882
    892
  25. #303
    Sep 2011
    Wales
    72
    787
    179
    .....thanks Trig......now this sounds like a dumb question but.....have they got any internal plumbing?....interested in making one...
  26. #304
    Jul 2006
    bristol
    10,882
    892
    Hi bud I'm not shore what there like inside if there's some dark art or special shape they need to be but as far as I know they just hold a pot of fuel to stop fuel surge ( so you don't get air in the fuel lines).
    I would say if your making one make it tall thin with the main feed to the pump at the bottom.
    Did a quick goggle search images but not much of internal pics on there.
    I'm shore someone on here will know how they work
  27. #305
    Jul 2006
    bristol
    10,882
    892
  28. #306
    Jul 2006
    bristol
    10,882
    892
  29. #307
    Jul 2006
    bristol
    10,882
    892
  30. The Following User Says Thank You to trig For This Useful Post:
  31. #308
    Oct 2011
    uk
    168
    20
    as long as your lift pump flow exceeds the demand of the engine/whatever the main pump delivers, you can get away with a small pot.... long and tall will work better than short and squat
    how much room you got?
  32. The Following User Says Thank You to anguz For This Useful Post:
  33. #309
    Sep 2011
    Wales
    72
    787
    179
    ......Trig....thanks for doing the R&D for me,and anguz....not a lot of room at all.......When I finish the rear of the chassis I'll have more idea on space.
  34. The Following User Says Thank You to Blackvette59 For This Useful Post:
  35. #310
    Oct 2011
    uk
    168
    20
    i have a few 1l oxygen bottles..... thick enough to drill and tap with what ever fittings you need
  36. #311
    Sep 2011
    Wales
    72
    787
    179
    ....anguz...thanks for the offer,but I've got an old Moon ''puke tank''...that I will use...I think....talking it over with a friend today,and he says I'm probably ''over thinking'' this....''its in the tail,and you can't see it....buy one..its cheaper''....he doesn't really know me...
  37. #312
    Sep 2011
    Wales
    72
    787
    179
    ...this is the tank I was thinking of,but Alex in Torques said he could put me in touch with a guy in Ross on Wye who could custom build me one...I'll pay him a visit and make my mind up....
  38. #313
    Jul 2006
    bristol
    10,882
    892
  39. The Following User Says Thank You to trig For This Useful Post:
  40. #314
    Sep 2011
    Wales
    72
    787
    179
    ....its that time of year again....Have a great Christmas,and a great,or better New Year.....thanks for all your help over the year,and look forward to your continuing support for 2014......Thanks......
  41. The Following User Says Thank You to Blackvette59 For This Useful Post:
  42. #315
    Jul 2006
    bristol
    10,882
    892
    Right old timer new year lets see this finished please.
  43. #316
    Sep 2011
    Wales
    72
    787
    179
    .....Trig,if this ''old timer'' has not gone to that big scrapyard in the sky...you never know......lets hope 2014 will be good to us all....all the best mate.
  44. The Following User Says Thank You to Blackvette59 For This Useful Post:
  45. #317
    Jul 2006
    bristol
    10,882
    892
    Lol I didn't mean it like that more like a old metel work book I have showing you how things should be done.
  46. #318
    Sep 2011
    Wales
    72
    787
    179
    ....I don't know about that Trig....
  47. #319
    9,210
    Quote Originally Posted by Blackvette59 View Post
    You may have gone past this point now but I have some ss tube offcuts that would make one.
  48. The Following User Says Thank You to alladdin For This Useful Post:
  49. #320
    Sep 2011
    Wales
    72
    787
    179
    ...alladdin...thank you,that's so kind,but I really need to get this sucker finished,and all the time I spend ''making bits'' could be spent building....(it is no cheaper sometimes to build parts)..so bought off the shelf.....but again thanks for the offer.....
