Page 1 of 16 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 LastLast
Results 1 to 40 of 630
Thread: Duratec powered vintage Sprint car
    Mechanic Blackvette59's Avatar
    Sep 2011
    Wales
    72
    787
    179
    Don't know if this will be of interest,but I decided to restore an old Ford special about 18 months ago.I've always built cars ,but hadn't built a Ford 4 banger since the late 60's.After a long while thinking,I decided to run a 2.0 Duratec.....this has put me right outside my comfort zone...never used a computer car in my life (except for the gofers).I hope you guys can help,when I get there.
    This is where it all started a few body parts,and some plans drawn of the back of a fag packet,and a few old parts....
    Sep 2011
    Wales
    72
    787
    179
    Re: Duratec powered vintage Sprint car
    When I started the project I was going to use a Small Block Chevy,but I thought I might kill myself,so a Duratec it was.I know this sounds strange ,but it would have been easier to use the Chevy....the Duratec is the same length (go figure) but deck hight is really big.(V8's are very low) When I had to figure in all the bits I need to run this motor it has been quite a challenge.My friend set up the cassis on his jig,and I could not wait for it to come home.
    Some more mock up at home, a Ted Halibrand grill (same man who made the wheels ) came from a really great guy from the States,Johnny Fast,the back axel is a Winters Quick Change and a new Duratec turned up.Now the fun really starts.
    Sep 2011
    Wales
    72
    787
    179
    The first problem I had was the original oil filter.....motor would not fit inside the rails.....this was solved using a remote filter plate.Problem two came from the gear box.....the Rocket box was a little long but those nice guys at Kirky put a hole for the gear shift,but I didn't like it so a solution came in the shape of a Quaif short tail shaft (I am learning...didnt know they did one,but I do know)......
    Nov 2003
    Wirral UK
    6,740
    257
    Looks like a very interesting project, crack on with it!
    http://escort.accelerator.org
  5. The Following User Says Thank You to exboyracer For This Useful Post:
  6. #5
    Sep 2011
    Wales
    72
    787
    179
    The motor needed some mounts,so Retro Ford supplied some engine plates,and I fabbed some 'vintage looking' mounts with Transit rubbers.The gear box needs some 'trick' mount and that is still in 'corn flake' mode.The motor has not been mounted yet as more adjustments need to be made before final welding in.
  7. #6
    Sep 2011
    Wales
    72
    787
    179
    Now,aside from the computer,I had two problems that were causing me some sleepless nights.....the steering,and the fuel tank.I had an original Schroder steering box,but this was beyond repair..and I was just about to buy a new one (they are still made) when I bumped into a rodding buddy who knew about my car.....he said he may be able to help.....this is the drawing....and the box.This was carved from billet,sand blasted and coated in Dow 7 coating...it looks better than the original and has much better ratios.
    The fuel tank on sprints holds about 36 gallons .....far too much weight......so I needed about a 11 gallon tank....a drawing and some corn flake packet templates got it roughed in....FOZ racing in the States came up with the poly tank.
  8. #7
    Sep 2011
    Wales
    72
    787
    179
    I needed some instant gratification so decided to dress up the motor.I did not like the plastic cam covers,and started looking for a replacement.I could not find one I liked in the UK,but a friend runs a Duratec in a modern sprint in the States,and he put me onto a shop that helps him out.A few weeks passed and A.R.E set me a cover.I think its a nice part,but I wanted to cover the plug wires.My friend made a finned cover in billet,it was sand blasted,painted and the fins polished...I think it looks cool.
  9. The Following User Says Thank You to Blackvette59 For This Useful Post:
  10. #8
    Sep 2011
    Wales
    72
    787
    179
    The water rail was supplied by Retro Ford...this will be polished,after all the bumps are removed,and all the holes I don't need filled.The header is mine...Retro Ford supplied the flange(that Dave is a cool guy and has helped lots),Cone Engineering in the States supplied the cone,dahhhh,and I bought some dairy bends,(didn't know there were so many radius bends available) then my mate Stainless Steve put it together......Ive just had an auger style silencer,and the rest of the system should be built over the next few weeks.
  11. #9
    Sep 2011
    Wales
    72
    787
    179
    Well thats as far as it goes.....I am in the States for the next few weeks so work won't resume till I get back home.I have been working on the pedals,and these need to go in next...this is what I have come up with so far,but they need some work.Once the pedals are in,the steering box can go in ,there are a few body panels to finish.Oh ...and Ive got a cool fuel cap....a Halibrand/Beck part.That gold thing on the body side is my dry sump oil tank,its a little worn,but can be rescued.....again thats it for now.....
  12. The Following User Says Thank You to Blackvette59 For This Useful Post:
  13. #10
    Feb 2007
    Norway
    942
    58
    That's really cool
    Looking forward to sesong this progress!
    67 TVR VIXEN V8
  14. The Following User Says Thank You to Sonus For This Useful Post:
  15. #11
    cool project nice to see something different
  16. The Following User Says Thank You to Graham For This Useful Post:
  17. #12
    I support TS Decade Plus User
    Quarterless's Avatar
    Apr 2004
    Essex
    943
    Wow stunning build. I'm loving the cam cover and spark plug. I can see alot of people wanting that themselves.
    My band: http://www.myspace.com/sanswilfred
    For Sale: http://www.turbosport.co.uk/showthread.php?goto=newpost&t=126514, My items for sale on E-bay,
    Wanted: T5 gearbox, Tremec TKO 600, PACE XE Dry Sump, Tilton floor mount pedal box, Large BMW LSD's 3.5:1 - 5:1, 2.2-2.4ltr petrol Frontera/GM engines.
  18. #13
    Sep 2011
    Wales
    72
    787
    179
    Thanks for the kind comments.......this is the easy bit....I am terrified over the comp controlled engine and fuel systems,but I am sure we'll get there....
  19. #14
    Racer Decade Plus User sambo's Avatar
    Oct 2005
    Bexhill on sea
    1,934
    107
    You have successfully made a Duratec look good! well done!
    Fantastic project.
  20. #15
    Sep 2011
    Wales
    72
    787
    179
    Sambo.....I am glad you like it....wait until you see the engine breather I have planned....if I pull it off it could look good.What is it with plastic parts?
    A little while back I mentioned a friend who has a midget sprint with a Duratec.I have tried to read as much as I can on this site about Duratec's.........well I read about the maximum angles that they could be run at(can't remember what they are),but check out CSG's in his car A few modded Stateside Duratec's he sent me photos of.....
  21. #16
    Dec 2006
    romford
    great build mate is the vette stock or modded(building a 62 at the moment)
  22. #17
    Sep 2011
    Wales
    72
    787
    179
    Well spotted......she's as stock as a rock......but,I'am in North Carolina in three weeks and a Fatman Fabrications set of lowered uprights and lowered steering arms have my name on them...I dont want to change it too far from stock,but a steering and brake upgrade could be on the cards.I have used her for the last seven years and this is not a great driving car,but I love her to bits....................have you got any shots of your 62? would love to see them.
  23. #18
    Jan 2011
    clacton essex
    1,731
    70
    ah man thats stunning a differant, im guessing this is going 2 be road legal then???
  24. #19
    Spanner Monkey Unclebuck's Avatar
    Nov 2009
    314
    Stunning build mate, with lots of 'out of the box' thinking. I'm looking forward to seeing this one progress.
  25. The Following User Says Thank You to Unclebuck For This Useful Post:
  26. #20
    Dec 2006
    romford
    pics of my vette here. she has a long way to go
    http://s51.photobucket.com/albums/f3...tte/?start=all
  27. #21
    Loving this, nice to see something out of the ordinary with great attention to the design of things.
    Keep it coming...
  28. #22
    May 2010
    North Yorkshire
    213
    17
    Great project, very creative. That belt driven duratec in the race car looks interesting, do you know who develops them?
    ​enquiries@flintec-eng.co.uk
  29. #23
    Sep 2011
    Wales
    72
    787
    179
    Quote Originally Posted by rwd2ltrfiesta View Post
    Now that would be cool.....
  30. #24
    Sep 2011
    Wales
    72
    787
    179
    Quote Originally Posted by novanut64 View Post
    Hey its a Vette.....I love it....
  31. #25
    Sep 2011
    Wales
    72
    787
    179
    Quote Originally Posted by flinny1986 View Post
    I'll be seeing CSG in a few weeks and ill get some more info and send you a PM..(CS Gerry his name)
  32. The Following User Says Thank You to Blackvette59 For This Useful Post:
  33. #26
    Nov 2009
    essex
    6,623
    338
    this is brilliant, absolutely love the steering box too , i just want the next updates already , plus dont worry about the electrickary bits on the engine, the amount of people on here that know wiring looms inside out your'll be sorted
  34. The Following User Says Thank You to caprimentle For This Useful Post:
  35. #27
    Racer Decade Plus User angliaant's Avatar
    Dec 2006
    Essex
    31
    1,841
    31
    what a fantastic project , always loved the 'vintage' look , and it looks like you should have something that looks vintage but is as reliable as any decent modern car ! what an awesome build , love all the little touches like the dry sump tank the rear leaf etc !! keep us up to date man !
    and while youre in the states keep your eyes peeled for a Tremec TKO gearbox please
    thanks Guys !
  36. The Following User Says Thank You to angliaant For This Useful Post:
  37. #28
    Sep 2011
    Wales
    72
    787
    179
    Thanks for your kind comments......should have let me know about the gearbox....could have smuggled it back for you....
  38. #29
    Sep 2011
    Wales
    72
    787
    179
    Caprimentle.....thanks for the kind comments.......just got back from the States.....every one involved in helping me knows I am back ,so I hope it wont be long before the build continues.......
  39. #30
    Apr 2004
    Bangkok, Thailand, Thailand
    4,346
    479
    Forget the car...
    I love the beard and tashe
    Seriously... cracking project
  40. #31
    Bodger G.Man's Avatar
    Aug 2005
    Bristol
    111
    Wow what a stunning piece of work and quality fabrication.
    Mightily impressed.
  41. The Following User Says Thank You to G.Man For This Useful Post:
  42. #32
    Sep 2011
    Wales
    72
    787
    179
    Thanks for your kind comments,but it would not be possible without a band of good guys,both in the UK and the States, who help a lot. (THEY HAVE THE SKILLS TO TURN MY IDEAS INTO REALITY) ......
  43. #33
    Sep 2011
    Wales
    72
    787
    179
    flinny 1986.....they are made by Circle Performance in Brockton Mass.....htpp://www.circleperformance.com/global23.htm..........
  44. #34
    Sep 2011
    Wales
    72
    787
    179
    Cool Re: Duratec powered vintage Sprint car
    I know its OT but I thought youd like this........
  45. #35
    Pit Crew Hoogi's Avatar
    Jul 2008
    Lancashire
    1,590
    I did like the opening few words.........."Don't know if this will be of interest".
    As you can see from everyones replies................."Very Interested"................this is going to be stunning when finished.
    Looking forward to the updates.
  46. The Following User Says Thank You to Hoogi For This Useful Post:
  47. #36
    Oct 2004
    get me on my beeper,beeper
    11,882
    just had a read through this aND THAT IS SOME FANTASTIC WORK YOU AND YOUR GUYS HAVE DONE BUD.I LOVE IT AND THE ENGINES ARE GREAT
  48. The Following User Says Thank You to PIG For This Useful Post:
  49. #37
    Dec 2006
    denmark
    36
    64
    Really fantastic fabrication skills you and your mates have.
  50. The Following User Says Thank You to fordtosserne For This Useful Post:
  51. #38
    Sep 2011
    Wales
    72
    787
    179
    Still getting over the jet lag,but managed to get out and got a little work done.The hood has been trimmed and the cowl moved forward,managed to get some vintage hood latches,and fitted these.....I set the hood up to be side opening,but if I can get latches to match ,I am thinking it could be cool if both sides open.Now only some minor adjustments to get good gaps and that will finish the body.These were not sophisticated cars and little attention was paid to fit and finish,but I will try my best to get it right.Had the dash cut out,so this can now be fitted....no decision on gauges yet.....but there is no drive from the gear box so I'll have to work somthing out.Made a corn flake box template for the breather plate,this will be finned and an open breather fitted.The light was failing so time to finish for the day,waiting for some more parts to arrive,hope they come tomorrow.
  52. #39
    Sep 2011
    Wales
    72
    787
    179
    Rolleyes Re: Duratec powered vintage Sprint car
    Oh ,this is what I am trying to come up with.............................
  53. #40
    Sep 2011
    Wales
    72
    787
    179
    This is a car that Josh restored.....the red car is early.....and this is late....1969......I'am trying to take the best of both cars.....
