Results 1 to 8 of 8
Thread: 2.9 pistons / 1.6 diesel conrods
    Apr 2018
    Slovakia
    9
    hello all
    please help me
    compression ratio of 2.9 pistons +1.6 diesel conrods in pinto with not skimmed head + 1.5 mm head gasket?
    Thank you
    Apr 2013
    S Wales
    233
    432
    Re: 2.9 pistons / 1.6 diesel conrods
    Try this on Android if you know your measurements :
    https://play.google.com/store/apps/d...=cal.ratio.com
    Apr 2018
    Slovakia
    9
    hmm
    Apr 2018
    Slovakia
    9
    heeeelp , i havenīt got all parameters
    thanks
    ps: low comp or high comp?
    Mechanic snapper1's Avatar
    Oct 2010
    Chelmsford
    67
    670
    27
    There are a lot of assumptions here so please check...
    Pinto Rod 127mm
    Cosworth Rod 128.5mm
    Diesel Rod 130.2mm
    V6 2.8 piston is 1.5mm shorter than Pinto piston ARE 2.9 PISTON THE SAME?
    My V6 piston was 0.38 below deck
    V6 2.9 on Desiel Rod could be 1.32 above deck
    You need 0.9mm (0.75 min) piston ring head clearance
    With a 2.2mm gasket your compression ratio would be 10.425 to 1
    With a 1.5mm gasket your compression ratio would be 11.34 to 1
    Your clearance would only be 0.18mm
    PROBABLY MAYBE
  6. The Following User Says Thank You to snapper1 For This Useful Post:
  7. #6
    Apr 2018
    Slovakia
    9
    2.9 piston is forged
    Heigh 39mm
    Diameter of forged part IS 60mm x 1.5 mm
  8. #7
    Oct 2010
    Chelmsford
    67
    670
    27
    Quote Originally Posted by Halatajfun View Post
    Heigh 39mm
    I don’t know what “diameter of forged part is 60mm x 1.5” relates to so my calculations are for a flat top piston.
    Taking all my assumptions from my previous reply but reducing the piston compression height by 1.1mm gives
    10.25 to 1
    For A really accurate compression ratio you need to know
    Numbers in () are my assumptions
    1. Bore (93mm)
    2. Stroke (76.95mm)
    3. Combustion chamber volume (48cc)
    4. Piston deck height (-1.282mm) - = Piston above block deck, + = Piston below block deck
    5. Gasket bore (94mm)
    6. Gasket crush thickness (1.5mm)
    Rod length is not important if you can measure the piston height above or below block deck.
    Combustion chamber volume is important as these can vary between 48cc and 50cc on a standard head or could be much less if skimmed
  9. #8
    Oct 2010
    Chelmsford
    67
    670
    27
    Heigh 39mm
    If that is a dome on the piston then your compression ration is now 10.431
