Results 1 to 14 of 14
Thread: 2.8 inj gearbox to 2.0 pinto?
    Feb 2009
    aberdeenshire
    891
    87
    am i right in thinking this will mate up to my pinto ? if i cut a bit off the shaft? not sure how much to cut ???
    3,241
    Re: 2.8 inj gearbox to 2.0 pinto?
    There are 3 length shafts - 4 pot engines mostly had 175mm shafts, P100's and Transits had 195mm and V6's had 205mm. So need to establish that you have a V6 box and if so, need to reduce by 30mm and also reduce the splines a bit maybe 10mm for additional clearance - I never had this problem, just read it in Classic Ford mag.
    I don't think it's just a matter of cutting the end of the input shaft off with an angle grinder. You would then need to get the end of the shaft machined for the spigot bearing in the crank. It would be much easier to find the correct gearbox and save yourself a lot of hassle.
  5. #4
    Feb 2009
    aberdeenshire
    891
    87
    i read that you can buy a spacer bracket?
  6. #5
    Quote Originally Posted by mk2 stevie View Post
    you would need a spacer around 1/2 thick between the gearbox and bell housing, but many many shafts have been shortened with an angle grinder
  7. #6
    you just cut a bit off the end of it, then grind the splines back a bit, an angle grinder isnt a pretty way of doing it but many have done it that way
  8. #7
    3,241
    Yes - it really is that simple! What's left of the input shaft after trimming is same dia. so fits the spigot bearing once a chamfer is added, then attack the splines with the 'angry end' (Project Binky reference!). A spacer could be used but will also require the gearstick hole be moved back also and as they tend to conflict with the handbrake lever in 2nd gear its more hassle than its worth!
  9. #8
    Feb 2009
    aberdeenshire
    891
    87
    Grinder it is then 😂 only metal 👍
  10. #9
    Oct 2019
    Barry South Wales
    30
    I did this to mine just cut the shaft by 30mm and chamfer the end
  11. The Following User Says Thank You to Andy Corne For This Useful Post:
  12. #10
    Sep 2005
    Scottish Borders
    14
    You'll need a pinto bellhousing as well. The Cologne stud pattern is different.
  13. #11
    Feb 2009
    aberdeenshire
    891
    87
    Quote Originally Posted by Big Daft Lad View Post
    yes have an alloy one
  14. #12
    Nov 2004
    Sweden
    1,167
    I have done it myself, with a lathe and with simpler contraptions.
    I would however give the spacer option a re-think, if you have the room. 2.8i type 9's are not that common any more and it is nice not to ruin stuff. If it is at all possible to use a spacer that would be my first choice. That would also mean that if you wreck the gearbox, another 2.8i type 9 is a drop-in replacement.
    Gustaf
  15. The Following User Says Thank You to therealpinto For This Useful Post:
  16. #13
    Sep 2005
    Scottish Borders
    14
  17. The Following User Says Thank You to Big Daft Lad For This Useful Post:
  18. #14
    Sep 2005
    Scottish Borders
    14
  19. The Following User Says Thank You to Big Daft Lad For This Useful Post:
