Hydraulic handbrake
can anyone help me, please?
I have a vertical hydraulic handbrake to install in my car.
How can i do it?
I just have to plug a pipe fom the hydraulic handbrake in to each of the rear calipers?
Will i loose braking performance?
Thanks a lot.
Helder
Re: Hydraulic handbrake
you feed the fluid going to teh rear brakes through the handbrake cylinder, you wont loose brake performance
Thanks Graham...
If i put a oil reservoir on top of the handbrake cylinder, and then connect the exit pipe from the handbrake cylinder, to the rear calipers, will it work ok?
Thanks.
Helder
no that wont work, you need to feed the handbrake cylinder with the fluid coming out the main rear brake master cyl
Thanks a lot Graham!
