Results 1 to 3 of 3
Thread: Which fitting for girling cylinder (bias pedal box)?
    Dec 2009
    Netherlands
    413
    19
    hi,
    I am in the process of fitting a bias pedal box to my Escort mk2. All is going well, but I am looking for the right hose fitting (connector) for the Girling cylinder outlet (3/8 UNF) to flexible hose.
    I would like to run flexible braided brake hoses from the two Girling brake cylinders to the bulkhead. From the bulkhead I will be using copper brake lines to the calipers.
    Which connector / union should I use at the cylinder outlet?
    I have ordered this one: https://www.burtonpower.com/3-straig...unf-bfu10.html
    but in my opinion it is too short.
    Should I simply order this one: https://www.burtonpower.com/3-straig...unf-bfu12.html
    Or do I need something else
    for illustration;
    The picture below shows the flexible hose I would like to realize.
    4,888
    Re: Which fitting for girling cylinder (bias pedal box)?
    I've used Banjo fittings at the outlets.
    Why go from braided hose to copper?
    Dec 2009
    Netherlands
    413
    19
    Check. Banjos are on the list
