Narrow Atlas SKF Rear Wheel bearing
I have just gone to fit an Genuine SKF Rear wheel Bearing (Part Number 361964) onto a Quaife Heavy duty Grp1 half shaft and have found that the chamfer on the side that I had thought would be oil side isn't big enough to clear the corner radius on he shaft.
Do you fit the bearing with the raised shoulder facing outboard and the seal expansion spring the diff side?
Any help is much appreciated
Mick
