Results 1 to 4 of 4
Thread: Lowering front strut lower spring platforms
    Spanner Monkey longlegs's Avatar
    Jun 2010
    Herne bay Kent
    270
    Just got a set of roller top mounts as you all know they raise the suspension by a inch
    i allready have a set of uprated -1 inch springs on my capri struts which are only two years old
    am i right in thinking that if i want to return to my current ride height it should be possiable
    to cut the lower spring mounts and weld them on 1 inch lower
    Clint's Avatar
    Jul 2001
    933,604
    Re: Lowering front strut lower spring platforms
    Your find the wheel might hit the platform, certainly with bigger wheels its a struggle, coil-over conversions are the best way if you can afford it can be done for like £100 total.
  3. The Following User Says Thank You to Clint For This Useful Post:
    May 2007
    nottinghamshire
    176
    -2" springs!!
  5. #4
    Jun 2010
    Herne bay Kent
    270
    Will check out how much clearance there is for the spring platform thanks otherwise could be -2 inch springs then.
    cheers guys new it was worth a ask allways some one whose thought of some thing else .
