Mk1 cosworth installation .Fuel pipes question
Hi can I please get some advice I want to fit braided fuel lines to my cosworth mk1
But want to keep the standard fuel rail and regulator . Can anyone give me some advice on fittings for the supply and return to the rail.
Many thanks in advance Dylan
Re: Mk1 cosworth installation .Fuel pipes question
Easiest way would be a billet fuel rail. The standard cossy rail will need an -an adapter welding on or if someone now makes one for the feed as it has a funny connector, the return you will need hose to -an adapter from the regulator to join up to the braided line.
