Results 1 to 5 of 5
Thread: Wheel Studs
    Racer Decade Plus User alancdavis's Avatar
    Oct 2009
    cumbria
    69
    2,477
    Wheel Studs
    Changing to studs on the MK1 and bought longer 13.1 spline ,,,7/16 studs but the ones I took out seem to have bigger splines ?
    3,241
    Re: Wheel Studs
    Splines look tighter / finer as well on the shorter stud - could it be metric thread ?
    Oct 2009
    cumbria
    69
    2,477
    Re: Wheel Studs
    Just had some useful info
    Neil Fletcher Standard Mk2 studs have the same spline as a Mk1 stud and they are the same length - the thread is the main difference in that the 12 mm metric thread is very slightly coarser than the Mk1 7/16 UNF thread but you need to look closely to tell. In actual fact it was so easy to mix them up that Ford put a special mark a bit like a screwdriver slot in the end of a Mk2 stud so people could tell the difference. Those are not normal Mk2 studs.
    I'd not be an expert on later 80s stuff but I think that cars like Sierras and such like from that era had a metric stud with a bigger spline. I have heard tell of guys whose Mk2s damaged the normal splines drilling them out slightly and fitting the later metric stud - maybe........just maybe that's what those are but I'dnot be sure!
    Oct 2009
    cumbria
    69
    2,477
    Re: Wheel Studs
    Short one is off the car and i think it is 12mm thread and 14.3 spline the new long one is 7/16 thread and 13.1 spline ..also just found out the car has MK2 struts fitted which may be the problem
    Oct 2009
    cumbria
    69
    2,477
    Re: Wheel Studs
    Just thought if the spline looks finer it may well be 14.3 and not 13.1
