Cosworth YB 2WD Head and cams for sale Unskimmed
Hi Guys,
For sale is my complete 2 wheel drive Cosworth YB head that comes with original cams and pulleys, caps, buckets and valve gear.
The head is a later 2WD type with the three bolt thermostat, it was removed from a later Saph in running order. It is as far as I can tell unskimmed with a thickness of 138.83mm.
There are no signs of detonation in any of the chambers.
Only issue is that it suffers from is the classic YB snapped exhaust studs! There are three in the head that will need attention.
I would like £1300 for the head or best offer.
I can post the head at a cost depending on where you are.
Thanks for looking.
Re: Cosworth YB 2WD Head and cams for sale Unskimmed
