Results 1 to 14 of 14
Thread: 52" Std Atlas with 13x9 and Tarmac arches???
    Feb 2010
    Vila Nova de Poiares, Portugal
    47
    23
    Hi All members... I'm building a mk2 escort on tarmac arches and a 52" large std atlas axle. Yesterday I've borrowed a pair of minilite 9x13 and 8x13 both ET-12 and none of them fits the arches, they come out to much. Anyone with similar problem? How to solve this? Other wheel/brand with ET0, boreham arches??? HELP PLEASE!
    4,899
    Re: 52" Std Atlas with 13x9 and Tarmac arches???
    Hello,
    are the arches fitted above or below the swage (spelling?) line?
    How wide are they?
    If you look at the minilite website there is a photo of a white mk2, that has tarmac arches and 8/9 inch rims with a std axle.
    Feb 2010
    47
    23
    See pictures...Click image for larger version Name:	12938241_10209687530372015_5279223079369729359_n.jpg Views:	83 Size:	73.1 KB ID:	85481Click image for larger version Name:	Ford MK II 00191.JPG Views:	81 Size:	16.5 KB ID:	85482Click image for larger version Name:	Ford MK II 00194.JPG Views:	82 Size:	28.0 KB ID:	85483
    Feb 2010
    47
    23
    This one??Click image for larger version Name:	g_15_l.jpg Views:	82 Size:	139.7 KB ID:	85484
    4,899
    Yes that's the one.
    Feb 2010
    47
    23
    Arches seem the same and if the atlas is 52" don't quite understand. Would like to see the difference between ET0 and ET-12... anyone as a picture??
    Feb 2010
    47
    23
    Is the exterior profile the same and only on the interior the center part in the photo comes is more deep?Click image for larger version Name:	261.jpg Views:	81 Size:	32.9 KB ID:	85485
    4,899
    An ET-12 wheel sticks 12 mm further out than a ET0 wheel.
    I think with ET-0 and your setup you'll be fine with clearance on your wheel arches. Some make of wheels change the ET with a thick boss on the inner face of the wheel. If your ET12 wheels are like that then you could get someone with a large lathe to machine 10 to 12mm from it.
    Feb 2010
    47
    23
    Thanks all for the help. Got to try the ET0 and then we see if we need bigger arches...
    Quote Originally Posted by alvarinhas View Post
    Ford did a Monte Carlo spec wheel arch which was wider.
    4,899
    I have Gartrac Monte Carlo's on my car; they are about 1 inch wider than Gartrac Tarmac arches.
    Spanner Monkey paulmex's Avatar
    Aug 2004
    n.yorks
    357
    I’ve +1 inch tarmac arches with 9x13 -0 miniltes 52inch atlas they clear no problem mate
    Feb 2012
    CzechoSlovakia
    65
    350
    Hi. With 52" axle, 9x13" ET -12 and Monte Carlo arches (Gartrac) I have cca 10mm space
