Results 1 to 7 of 7
Thread: RS2000 Mk2 valve clearances
    Mar 2020
    Greater Manchester
    20
    What are the valve clearances for a 1979 RS2000 please.
    Re: RS2000 Mk2 valve clearances
    According to Mr Haynes, 7 thou inlet and 8 exhaust cold with a std cam.
    Jan 2016
    Hull
    246
    Correct me if I’m wrong but I always thought they were 8 and 10 thou cold
    Yes so did I, so I had a look in the Haynes Manual for the RS 2000 and that's the figures they quoted. Either way I don't think they would be far out.
    Mar 2020
    Greater Manchester
    20
    Ok, I can get a 15 thou in some and there's still slack. The markings on the camshaft are EP 26 and D-1 and Made in USA.
    3,242
    Quote Originally Posted by Overdrive View Post
    So.......... they need adjusting! Even aftermarket cams don't stray too far from OEM specs.
    Mar 2020
    Greater Manchester
    20
    OK, adjusted to 10 thou ex. and 8 thou in., was still running like a bag of shit so I went back to basics. Blew out carb jets twin 40 DCOEs and checked firing order, found 1 & 2 plug leads had been transposed. Fek, an easy fix but wish I'd started there before. Running much better but still a bit ropey, hopefully this will improve with further tuning and use (been off the road since 2002). At least I got to check the oil delivery pipe was spraying onto the cam lobes. Went for a short drive successfully (except a plug lead coming adrift) and next job will be new tyres as these are like driving on squares.
  8. The Following User Says Thank You to Overdrive For This Useful Post:
