Results 1 to 13 of 13
Thread: alloy wheel centre bore machining
    Feb 2010
    London
    90
    I'm looking for someone to enlarge the centre bores in a set of alloys. Has anyone got any recommendations? Ideally looking for somewhere not too for from se london/kent area. Cheers in advance, Rob
    Spanner Monkey longlegs's Avatar
    Jun 2010
    Herne bay Kent
    270
    Re: alloy wheel centre bore machining
    This company do alloy wheel refurbishment in gillingham kent they should be able to do it easily give them a call.
    lepsons 01634 580582 or www.lepsons.co.uk
    Feb 2010
    London
    90
    Nice one. I'll give them a call.
    Feb 2010
    London
    90
    Unfortunately they can't do it. Any other suggestions? Rob
    I support TS Decade Plus User
    Scott_B's Avatar
    Sep 2003
    ESSEX
    2,291
    47
    There used to be a little engineering workshop behind Elite in Rainham Essex who did all their wheel machining, unfortunately the fella who owned it died some years ago, but they must have somebody else who now does it for them, call them on 01708 525577 and ask for Bram (Paul Bramley) and im sure he will point you in the right direction.
    Feb 2010
    London
    90
    Cheers. I'll give them a try.
    Moderator+ Decade Plus User
    dangerousdave's Avatar
    Oct 2002
    London
    15,132
    65
    Failing that im sure these guys in high wycombe can sort it http://alloyweldcraft.co.uk/index.htm need them to fix one of the wheels i just bought that had cracked and been badly welded and filled up with filler by the last owner!
    Feb 2010
    London
    90
    Quick update on this. Spit and Polish in Kent are able to sort this out. 01732367771 is the contact no.
    Spanner Monkey Dr Knockers's Avatar
    Dec 2008
    London
    331
    Quote Originally Posted by RobB View Post
    how much did the charge out of interest?
    Face book MyBigFatRubber for all your split rim wet dreams...
    Feb 2010
    London
    90
    Haven't had them done yet. I think it depends on the amount to be machined out and any they need to have a look first. Approx £20 ish each I was quoted on the phone.
    Dec 2008
    London
    331
    thats seems like a good price, a mate was quoted 40 each at a machine shop..... keep us posted please
    Pole Position Decade Plus User freddy686868's Avatar
    Jul 2010
    South Wales
    4,689
    221
    I work in a machine shop as an aircraft engineer if your really stuck ;-D
    boXXer
    Guest
    what about redrilling Mounting holes? anywhere that can do that?
