Results 1 to 5 of 5
Thread: MK1 Escort Owner Saying Hi
    May 2020
    leicester
    New member here just saying hello! I have a 1970 Mk1 Escort that I'm currently fitting an St170 engine to. I came across this site due to a particular thread about the fuel tank outlet fitting on a mk1 escort (probably some of the other older fords aswell i guess), which I have adapted to take a 10AN fitting to supply the pump.
    I did this using the original tank fitting, drilled out and a 10AN fitting welded on, but I really wanted a 1 piece adapter. The problem is the fitting in the tank is really obscure, at 1"-12unf. And nothing is right, BSPP, JIC, ORFS - ive treid everything and every catalog I can find!
    So I found a company that will custom make the adapter, so it will be male 1"-12 - > male 10AN, with a flat sealing surface on the tank side to take the original seal, and a hex in between to tighten the adapter into the tank. The company have said they can do 10 @£25 each, or one off at £59, so I was wondering if anyone was interested in chipping in, or if in fact anyone else needed them at all!
    Anyway I've tied to add some pics of the car, but it only seemed to like on of them?
    Kind Regards
    Joe
    Dec 2019
    New zealand
    25
    Re: MK1 Escort Owner Saying Hi
    Welcome! Would love to see more pics, loving that green.
    looks good from the sneaky peek, lets have some more
    p.s welcome
    May 2020
    leicester
    Hi all,
    sorry im really struggling to get the res of images correct to load on here! Ive attached on of the mk1 in the rollers at NMS when it still had a pinto in it. Also one of the st170 on the throttle bodies, and also one I took when i still had my RST and Mk3 focus st3 estate
    Name:  71F23608-5C67-4342-8345-B523F1A0925C.jpeg Views: 158 Size:  28.0 KBName:  FF3831A0-78A3-490B-AB83-374294F1C8C5.jpeg Views: 141 Size:  30.9 KBName:  93ABB9A8-8153-4E4A-BC5E-7DFA86260568.jpeg Views: 485 Size:  32.4 KB
    3,641
    Very nice, I’m building a Zetec Mk1 just now, what size of wheels and tyres are on yours?
