does that work and if so what bell / hyde. clutch were u using ?
is the block not based on a xflow? if so the normal cosworth bellhousing will fit
T5's are fine for boosted engines but not so good for high rpm engines, just in case you are thinking of bolting a NA BDG to a T5 do not do this unless it has a dog gear kit fitted
t5 was designed for low revving v8's.
