Master Cylinder Refurb or Pedal Bias Box
Hey,
my standard master cylinder has begun to play up, seals are done, no rear brakes. Is it better to get it refurbished or fit a pedal bias box? The car will be driven hard on the road, but cannot see it being tracked or rallyed any time soon.
Any advice on which direction to go?
Re: Master Cylinder Refurb or Pedal Bias Box
ive fitted many a bias pedal box, but if you ask me in a road car best stick to standard master cylinder and servo set up
Yep
Just fit a brand new mastercylinder,
Plenty fine for road once all renewed
The Following User Says Thank You to OPPOSITELOCK For This Useful Post:
Thanks Guys! I'll get it refurbished.
...and use new brake fluid.
Guys,
I finally got my refurbished dual circuit Master Cylinder back and plan to refit tonight. I have a question on refitting it, does it matter which outlet port is connected to which set of brakes (front or rear)?
yes it does, i know that for sure because my mate connected his up wrong, get it the wrong way round and you will have a lot of rear brake bias, it will want to swap ends braking in the wet
Makes sense!! Found this image for the circuit and set it up as per the image. All works fine! Thanks for the help!
