Valve information needed
I am doing a modification on an engine and need some inlet/exhaust valves with an 8mm stem, the Escort CVH engine is listed as having these but I am not sure that they do have an 8mm stem.
(The older Kent Xlows & Essex V engines had 7.9mm stems as standard but valves with oversize stems were available and the head reamed to suit but these are not suitable for my needs)
Can anyone tell me if the CVH valves are actually 8mm and not a slightly smaller stem, if possible if anyone has some old or new CVH valves to measure I would be most grateful.
Thanks Brian.
