Results 1 to 6 of 6
Thread: Water rail
    Mechanic Nelly's Avatar
    Oct 2007
    eastbourne
    726
    10
    Water rail
    When i bought my engine it came out of a kit car and had a fwd water pump and associated pipes. I have managed to get all the rwd bits to make it work in my starlet but can anyone tel me how the copper tube from the top hose housing is supposed to be sealed into the top of the water pump?
    Pit Crew Turbosport Subscriber keg's Avatar
    Mar 2008
    nottinghamshire
    905
    Re: Water rail
    Alright mate I just put some gasket sealant around mine as the just slot together and with the pressure of everything being tight hold together.
    I never had a problem with mine leaking either
    Oct 2007
    eastbourne
    726
    10
    Re: Water rail
    Quote Originally Posted by keg View Post
    Cheers keg, it seems quite a baggy fit i wasnt sure if sealant would be up to holding the pressure. how would it have been sealed out of the factory?
    Mar 2008
    nottinghamshire
    905
    Re: Water rail
    Quote Originally Posted by Nelly View Post
    Mine is Quite a tight fit inside the hole no pun intended. I'm sure mine has a small lip on the bottom similar to the end of the water rail that goes across the engine
    Oct 2007
    eastbourne
    726
    10
    Re: Water rail
    as you can see in the pic mine just has a plain end. maybe i will flair the end out to tighten things up a bit.
    Jun 2011
    Vic, Australia
    Re: Water rail
    that's odd, their meant to have an O-ring at either end. I do have aluminium replacements if you need one
    Custom 4AGE 20V conversion parts:
    S-86.com
