Results 1 to 2 of 2
Thread: More start problems
    Dec 2011
    Lisbon
    More start problems
    Hi guy's and gal's
    We are rebuilding our fir rsturbo from 89 on our garage. Same problem as usual, fuel comes out by the cold start inj but from usual ones no fuel. We have 2 padles and we tried with both and the same simptoms was there. We disassembled one of them but unfortunatly we could not find information about values and tolerances to rebuild at least one. Please someone have the schematic, tolerances and values of elecronic parts of them that could provide? I already soaked the "head" on wd40 o try to loose it, tryed to test the fuel valve on bench with 12v aplied (even if i don't have any info about it) wih no results. I was searching already on this and some other foruns but no info. The crankshaft for ecu control is from distributor yes or it exist another one? Thank you for your time
    Best Regards
    Hugo
    Dec 2011
    Lisbon
    Re: More start problems
    Solved hope will help somebody. Fuel pump did not had nice pressure.
    Best regards
