Results 1 to 7 of 7
Thread: Which CWP ratio '
    Jul 2011
    ferrara italy
    72
    Which CWP ratio '
    I boys.I need an advice for my Escort mk2 built for italian rally. My car it's 1.6 x-flow whit about 140 bhp. Gearbox it's type 2 whith Quaife gear 1st 2.500 2nd 1.640 3rd 1.220 and 4th 1.000. Rear axle it's Capri english axle 4,4:1. My indecision is: fit 4,9:1 or 5,1:1 ratio ????? Now I run whit 175/60/13 or 185/60/13. Any advice??????
    Re: Which CWP ratio '
    The gearbox you have seems to have the Quaife Clubman ratios which has a gap between second and third gear, ask me how I know that, because I had one in an Escort Twink in 1982. I also ran with 4.44 diff ratio before changing to a 4.1 when we went from 70 to 60 profile tyres.
    Why are you wanting to lower the diff ratio, to gain more acceleration? If you aren't carefull you'll under gear the car and have next to no top end speed unless you are reving the engine to 8000 rpm+.
    Jul 2011
    ferrara italy
    72
    Yes I need more acceleration expecially in 2nd and 3rd.
    Jul 2011
    ferrara italy
    72
    In my country,rally stage are very hard for my little 1.6 x-flow..... Stage have a lot of airpin bends and road with steep slope. I drive always in 2nd and 3rd but I hardly ever use the 4th.......
    Quote Originally Posted by ante1970 View Post
    If that's the case you might be better off trying a 5.1 ratio and see how it goes.
  6. The Following User Says Thank You to Forest_rallying For This Useful Post:
  7. #6
    Jul 2017
    Povegliano veronese
    27
    133
    70
    Le hai in fiches la 4.9 e la 5.1? Dal 75 all'81 la fiches si ferma alla 4.7 mi pare. Anche se onestamente sto parlando di rs2000, la 1.6 non ne ho idea.
    Comunque se non usi mai la 4 probabilmente avere la 5.1 ti aiuterebbe, noi con qualche cavallo in + ma assetto da terra siamo andati di 4.7, per avere un buon allungo e sfruttare la coppia del pinto, la 5.1 è roba da bda.
    Comunque c'è questo calcolatore, il diametro ruota è 552 con le 185/60/13
    Mettendo max rev a 7000 giri,
    con la 5.1 la prima la tiri ai 57, la 2 agli 87, la 3 ai 117 e la 4 ai 143
    con la 4.9 non cambia tanto, la prima ai 59, 2 ai 91, 3 ai 122 e 4 ai 150
    https://www.blocklayer.com/rpm-gear.aspx
    ps: sorry for the italian, but it's easier for both of us.
  8. The Following User Says Thank You to Enea For This Useful Post:
  9. #7
    Jul 2011
    ferrara italy
    72
    Ok thank you at all.I think of fit 4,9 which is included on fiche....Then I'll see how it goes.....Thank you very much!!!! Grazie mille non mi ero accorto che la 5,1 non era in fiche.
