Results 1 to 13 of 13
Thread: Wet Sump
    Oct 2015
    north wales
    31
    Wet Sump
    Just looking for some opinions,
    Im planning on building a 2.0 duratec to be used in my road rally spec mk2. it will also be used on the odd stage event, but mostly stages. But by this time there is a fair chance i will be getting a built engine by someone such as paul gardner
    The engine itself is going to be fairly basic - rods, pistons, cams, springs, standard unported head and the usual tensioner and keyway mods. so probably only looking at around 200bhp on a mx5 inlet manifold(due to regs).
    Ive spoke to a few local lads and they've recommended i go down the dry sump route just for reassurance. Which I completely understand. But they are also coming from pinto backgrounds which ive herd do have oil issues with wet sump
    so few questions:
    What are the duratec wet sumps like? Ive seen that retro ford, sbd, burton and dunnell all do one that look very similair if not eaxct the same. are they all? Is one better than the other?
    Do duratec's suffer from oil starvation?
    Is a Dry sump needed?
    25,110
    Re: Wet Sump
    if anything, i would say a duratec suffers more oil related bottom end issues than a pinto!
    one major plus point to dry sumping one is its a very tall engine
    Oct 2013
    Suffolk
    47
    194
    Re: Wet Sump
    I agree
    The pinto has less issues than the Duratec
    If you do stay wet sump
    Stay away from the cosworth/Caterham
    Kit as they are not as great as they should be
    Oct 2015
    north wales
    31
    Re: Wet Sump
    Thank you for the replys!
    looks like a dry sump will be fitted then!
    is there much between the titan/sbd and pace kit? non seem to get bad reviews
    ive also seen turbosport.net do a kit? but cant find much on this kit. so i guess stay clear...
    thanks again
    Jul 2018
    Aberdeenshire
    127
    29
    Re: Wet Sump
    Caterhams use a coswortrh kit that has an internal pump to avoid any issues with the external belt getting damaged and the catastrophic results that could cause!
    There's one on ebay just now actually (not mine), for about 750 i think. I seriously thought about it for my mk2 build but as it's just a fun road car I went for a wet sump (the retroford one, from motorsport tools).
    Spanner Monkey SimonD's Avatar
    South East Kent
    230
    22
    Re: Wet Sump
    Quote Originally Posted by Baron von Teuchter View Post
    Caterham now use a rebranded Raceline kit on most of there cars
  7. The Following User Says Thank You to SimonD For This Useful Post:
  8. #7
    South East Kent
    230
    22
  9. #8
    Jul 2018
    Aberdeenshire
    127
    29
    Re: Wet Sump
    Cheers, yeah that looks like the same idea - internal pump. Good price too!
  10. #9
    Oct 2013
    Suffolk
    47
    194
    Re: Wet Sump
    When I was at pace
    We had dealing with customers
    That had the cosworth kit
    Hence I have seen the damage that occurred
    Titans nop
    Turbo/s nop
    Sbd is titans
    Pace is not the same as it was
    But I have not had any dealings with
    The new pace stuff
    Opi is good lol
    But to busy to take new orders
  11. The Following User Says Thank You to Lacey For This Useful Post:
  12. #10
    Wet Sump
    Quote Originally Posted by sh123 View Post
    thanks again
    Never heard a good thing about them only bad
  13. #11
    Oct 2013
    Suffolk
    47
    194
    Re: Wet Sump
    I of my customers
    Used a Turbosport kit
    After half a session he needed a new engine
    And brought the correct kit from me
  14. #12
    Re: Wet Sump
    so few questions:
    I can virtually guarantee that if you go to Paul Gardner he'll want to fit a dry sump system to your engine as that's what he believes works best, tried and tested. We took him a 1700 BDA engine for a major overhaul some years ago and he was adamant the engine wanted a dry sump system and a steel intstead of cast crank which added about another £2500 to the Bill.
  15. #13
    Aug 2009
    Australia
    109
    Re: Wet Sump
    Mis-information about Duratec engine size: Yes it is a full skirt block, therefore LOOKS bigger, but its actual height from crank centreline to top of cam covers is almost identical to the Lotus twin-cam.
    Overall length and width is almost identical to the Twin-cam also, I have one each of them side-by-side for comparison.
    So If a Twin-cam will fit, then so will a 2.0l Duratec.
  16. The Following User Says Thank You to Durescort For This Useful Post:
