Basically i read a few months ago in classic ford about getting an axle shortened and welding new spring saddles to the axle. I mentioned something called pinion pitch and said it should be anywhere from 90 degrees to 7 degrees based on what angle you engine and gearbox sit at. So what i wanted to know is what would be the best angle for me to set my pinion pitch at as my engine and gearbox are at an anle of around 4.5 degrees. The car/van in question is a mk1 escort van and i would like to use it as a fast road van some track days and aboit of drifting. The axle has got all the brackets for coilovers and a four link kit whivh i might make use of as my skill sets advance but for now due to lack of skills and time i would like to use the original leaf springs. One last question for the forum gurus what leaf springs are best to use as i have the original mk1 escort van multileaf springs and some mk2 escort saloon 1.3 60mm wide single leaf springs. Any help and advice would be great. Thanks, John
