wheel alignment
Just had my mk2 escort alignment done ,guy mentioned getting a set of lower adjustable track control arms,i gather it makes the front set up more adjustable but looking out there are different ones on the market, any recommendations ,advice cheers murf.
Re: wheel alignment
have you got any issues with it now? what else you had done? what are you using the car for?
Re: wheel alignment
Adjustable TCA's are used for adjusting camber, normally when taller or lowered springs are fitted. A good set will set you back the thick end of £250, beware on cheap and nasty ones.
