2.8mfi OE stock cam and lift specs?
Hello all, I'm in search of the measurements of the valve lift and cam specs for the post 1982 (larger bearings). I'm trying to see if the drive train on my Cologne has worn.
Paul
Re: 2.8mfi OE stock cam and lift specs?
According to the Ford manual the cam lift for a 2.8i engine should be 6.7mm.
Just beautiful,thankyou so much Stroker. It's what I got,bought I'm struggling to get the 9.45mm valve lift
Just noticed,I got 6.07mm when they should read 6.70mm according to the literature you had kindly supplied
