Page 1 of 2 1 2 LastLast
Results 1 to 40 of 74
Thread: Best MK1 Escort suspension set up??
    Mar 2003
    Now over the pond North side
    3,540
    Suspension set up for a MK1 running a Pinto engine, 5 speed box and english axle.
    Used for road and track days. Going to shows and generally a toy.
    Not an every day car.
    Running 7" rims with 185/60/13 888's.
    What are your thoughts guys????
    Dazzle
    9,204
    Re: Best MK1 Escort suspension set up??
    "best" is a big ask but 300/70 billys with 190 lb springs work well. dont go too stiff on rear.
    Mar 2003
    3,540
    That's a good start as I have 300/70,s for the front
    As you're a very intelligent guy, what does the '300/70' stand for/mean??
    Dazzle
    9,204
    its the bump / rebound rates tho that may be rebound / bump rates
    and where the numbers are derived from
    thats blown my cover then
    300/70 tarmac settings 260/60 forest. the "gp1" rears work well to , 220/110 seems to be the setting in all (or most) sizes and lenghths.
    i should add that my experience is 20 years behind the times still my choice tho, others come and go.
    Racer Decade Plus User sambo's Avatar
    Oct 2005
    Bexhill on sea
    1,934
    107
    Agreed. Bilstein tarmac (300/70) are nice.
    If you are going do a lot of track days a spring rate in the region of 350lb is what you need to use, it does sound high but with the grip r888 can give you will have a lot of body roll, the last I was out at Lydden using 300/70 inserts and 275lb springs the body roll was excessive.
    Jul 2006
    bristol
    10,882
    892
    yeah go hard for track use but 300 at least I would say
    think boxxers on 400 or 450 something like that...
    TURBOSPORT SPONSOR Turbosport Sponsor evodave's Avatar
    May 2006
    Letterkenny, Donegal, Ireland
    1,589
    Are you running an anti-roll bar or compression or tension struts ?
    Are you on 2-1/4" coilovers or RS diameter springs ?
    Cheers,
    David
    Nov 2009
    essex
    227
    Don't go to low or you will screw up the roll centres.
    Mar 2003
    3,540
    Quote Originally Posted by evodave View Post
    Cheers,
    David
    Anti roll bar
    2 1/4" coilovers
    2.9 quick rack
    adjustable tca's
    roller bearing top mounts
    Think that's it??
    Dazzle
    May 2006
    1,589
    Anti roll bar
    2 1/4" coilovers
    2.9 quick rack
    adjustable tca's
    Think that's it??
    Is it standard width arb mounts or are you using double width or anti-dive kit ?
    What about bushes ? Standard rubber or poly bushes ?
    Cheers,
    David
    Mar 2003
    3,540
    Cheers,
    David
    Hmmm Not too sure??
    Need to have a look
    Dazzle
    May 2006
    1,589
    Hmmm Not too sure??
    Need to have a look
    Tightening up of the suspension by using poly bushes is a relatively inexpensive & worthwhile upgrade before anything else.
    Cheers,
    David
    Mar 2003
    3,540
    Cheers,
    David
    It was all rebuilt, I just don't know to what extent!!
    Dazzle
    Mar 2003
    3,540
    Cheers,
    David
    Right, just found out from previous owner:-
    The TCA's were all new inc poly bushes
    The ARB were NOS, but standard RS2
    The rear is all standard and original with the exception of the anti tramp bars which are poly!
    Is it worth going twink roll bar?
    Dazzle
    Mar 2003
    3,540
    Quote Originally Posted by eric View Post
    But how did it ride on the road?
    Do you use yours much on the road??
    What roll bar set up have you got?
    Dazzle
    Oct 2004
    get me on my beeper,beeper
    11,882
    Call powerstationand ask about 3-way ast's mate there not far from you and are very gdbut aye abit much for your requirements mate
    Mechanic terry's Avatar
    Jan 2004
    east mids
    933
    i have used leda on a few cars more expensive but worth the money definatly do what they say
  19. #19
    Mar 2003
    3,540
    Quote Originally Posted by PIG View Post
    Thanks Pig bud but as you say, way too much for me thanks
    Dazzle
  20. #20
    Mar 2003
    3,540
    Quote Originally Posted by terry View Post
    I thought Leda folded
    Dazzle
  21. #21
    Feb 2009
    essex
    1,986
    dave from leda now works for gaz shocks
  22. #22
    Mar 2003
    3,540
    Was just looking on E-bay and came across THESE Anyone seen/had any dealings with these??
    Dazzle
  23. #23
    May 2006
    1,589
    Quote Originally Posted by jimmy2006 View Post
    GAZ are good, we've sold loads of their Escort shocks &inserts.....they even have 300/70 & 260/60 inserts to suit competition Bilsteins but without the Bilstein price tag !!
    Cheers,
    David
  24. #24
    9,204
    GAZ are good, they even have 300/70 & 260/60 inserts to suit competition Bilsteins but without the Bilstein price tag !!
    Cheers,
    David
    thats a new one on me, what is the price tag ?
  25. #25
    May 2006
    1,589
    Around £105-£110 per insert & available in a range of ratings & lengths (some to order & takes 2/3 weeks) but a good alternative to a Bilstein.
    Please ask if you have any more questions.
    We should have a delivery of these soon !!
    Cheers,
    David
    www.classicandrally.com
  26. #26
    9,204
    same price as bilstein from gartrac tho
    Bilstein Short Insert 300/70
    £90.90 tax excl.
    Bilstein
    Reference : GAR2160
  27. #27
    May 2006
    1,589
    10% off that price for GAZ inserts to all Turbosport users. (would do them for £100each).
    It may be worth checking that price with Gartrac as I believe Bilstein had a price increase for 2012.
    Cheers,
    David
  28. #28
    Feb 2012
    coventry
    whats the best setup to have on the rear of the car?
  29. #29
    May 2006
    1,589
    Quote Originally Posted by 1sttimezetec View Post
    It really depends on what you are using the car for & your budget....there are many different combinations.
    Cheers,
    David
  30. #30
    Feb 2012
    coventry
    for instance what would be a decent setup on the rear for a part time daily/weekend warrior, the car would still have all the daily driver comforts but an engine that is really too much for the stock escort setup
    somthing that stand up to the rigors of daily abuse that modern cars go through & a setup that will improve handling, bring it up to a more up to date whilst keeping the live axle
    excuse the thread hi jack-just thought it was appropriate D
  31. #31
    May 2006
    1,589
    I'd begin with poly bushing everything & then as a minimum, for a road car, a set of anti-tramp bars & possibly a Panhard rod.
    Run it on some single leaf springs & set of decent shocks (GAZ adjustables is what I'd use for a road car) & that should be pretty good for most cars.
    Going further than this would involve turreting & possibly 5 or 6 linking but then yiur getting into a lot of fabrication work & you'd more than lilely lose the use of your rear seat too. A 5 or 6 linked car might be a bit extreme for every day though !!
    Cheers,
    David
  32. #32
    Feb 2012
    coventry
    ye i forgot to add that point in my previous post about what route to go with the rear axle without getting into four linking/loosing the rear seat if somone is running a more-door for instance
  33. #33
    Nov 2003
    Wirral UK
    6,740
    257
    For road / occasional trackday use IMO you don't need to go further than decent shocks, poly bushes, anti-tramp bars and a panhard rod, and even then the panhard is probably optional.
    http://escort.accelerator.org
  34. #34
    Dec 2009
    north east
    31
    17
    I'm currently restoring my mk1 escort at the moment i'm now at the stage where i need to decide what route to go with the rear suspension i'm going to be running a 2.0 pinto but in a few years i would like to drop a nissan CA18DET motor in would this require 4 links coilovers etc or could you get away with leaf springs? also would like to get the car quite low with 15" alloys, the car is bubble arched and i'm looking for a atlas axle to go in will only be getting used on the road.
  35. #35
    you can have 4 links and leaf springs, but you need to convert the front spring mount to a roller setup or the rear suspension will bind rather than move up and down as it should
  36. #36
    Feb 2012
    coventry
    bit of a long shot but any chance people could pop up some pics of there various suspension setups? me personally i'd find it super helpful
  37. #37
    Oct 2007
    Mold
    625
    28
    Tension struts with arb
    350lbs springs
    300/70 short billys
    rose jointed tca's
    sperical top mounts
    single leaf rears 140lb
    poly bushes
    panhard rod
    front lowered 5" rear 3"
    and the best of all is NON BUDGET TYRES and GOOD BRAKES
    mines on EVO xxxv1 and this is the best set up so far lol
    http://www.turbosport.co.uk/signaturepics/sigpic12022_2.gif
  38. #38
    9,204
    Quote Originally Posted by BIG-G View Post
  39. #39
    May 2006
    1,589
    350lbs springs
    300/70 short billys
    rose jointed tca's
    sperical top mounts
    poly bushes
    panhard rod
    Any pics of your car please ?
    Cheers,
    David
  40. #40
    Dec 2010
    york
    47
    170
    350lbs springs
    300/70 short billys
    rose jointed tca's
    sperical top mounts
    poly bushes
    panhard rod
    same set up here but not quite as low, i use it for rallying and handles real well, still on 6x13 4 spokes straightens up nicely from the oversteer
