Originally Posted by
NEILRS2K All,
Not been on here in quite some time due largely to inactivity with the install. However things have got going again, engine is in and we are looking to get it running.
One of the things holding me up just now is the oil feed to the guage and also to oil switch as wanting to run a light aswell. The parts that came out the block looked like conventional household brass plumbing fittings so not keen to use them!
Burton sell a tee piece which goes into the block via male 1/4npt thread. It has 2 X female ports on it. One 1/4npt for oil switch. The other is a 1/8npt port. I can't for the life of me get a fitting to go from this spare port to the standard RS2000 oil hose which then goes to the dash. Burton sell a 1/8npt to 1/8bsp male to male adaptor which connects a hose they sell however I don't know what the fitting it is at the dash side to know what I need to connect the hose to this end.
Any suggestions or things I should be looking at? How have other people done this?
Thanks and regards
Neil
