Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 41 to 80 of 160
Thread: four door mk2 road rally project
  1. #41
    Oct 2007
    Mold
    625
    28
    Re: four door mk2 road rally project
    looks good
    http://www.turbosport.co.uk/signaturepics/sigpic12022_2.gif
  2. #42
    Spanner Monkey jon jkd's Avatar
    Feb 2008
    mid wales
    244
    Quote Originally Posted by danknight72 View Post
    Yours looks fine mate, mine would have been easier if it had a flange all the way round like the one pictured on plr website!
    I had the same problem,photo showed flange allround tunnel then when it turn up it was cheap kind,not happy!!! Keep up the good work your cars coming along good,nice to see another 4 door for the lanes.Ive just started work on my 4 door on weekend,ill start a thread when i get round to it
    4 doors for the lanes........and shopping
  3. #43
    Mechanic danknight72's Avatar
    Nov 2011
    eastham wirral
    584
    20
    Get a thread going mate, have been busy priming the engine bay I'm really ready to get bolting things back on and out down the lanes
  4. #44
    Nov 2011
    eastham wirral
    584
    20
  5. #45
    Nov 2011
    eastham wirral
    584
    20
    Finally finished priming the engine bay
  6. #46
    Nov 2011
    eastham wirral
    584
    20
    Got the engine bay painted today looks good, used 2k aerosols
  7. #47
    Nov 2011
    eastham wirral
    584
    20
    Re fitted the wcxm,twin cam arb and double width kit, track control arms with new high tensile bolts. Then greased up the rbtms and assembled my bilsteins which have had new inserts and springs. Fitted the bilsteins with new bolts and some washers my mate machined for me
  8. #48
    Nov 2011
    eastham wirral
    584
    20
    Back on its wheels again
  9. #49
    Nov 2011
    eastham wirral
    584
    20
    Re fitted bonnet to set gap for welding drivers side wing on, had to repair front half of sill and inner sill
  10. #50
    Nov 2011
    eastham wirral
    584
    20
    Both wings welded on, front floors seam welded
    Took an age to get the passenger wing to line up quite happy with it now
  11. #51
    Nov 2011
    eastham wirral
    584
    20
    Got engine in with help from my bro and a borrowed crane
  12. #52
    May 2013
    South wales
    97
    Looking bloody lovely mate,I restored one outside I know hard it can be good on you buddy
  13. #53
    Nov 2011
    eastham wirral
    584
    20
    Had to grind away bottom of bell housing as it was catching flywheel slightly
    Steel bearing carrier and bearing didn't seem to fit with my sachs cover
  14. #54
    Nov 2011
    eastham wirral
    584
    20
    Painted floors and tunnel with zinc
  15. #55
    Nov 2011
    eastham wirral
    584
    20
    Picked up my roll cage today it's a 14 point turret mount safety devices
  16. #56
    Nov 2011
    eastham wirral
    584
    20
    Managed to get gearbox on and re drilled my extended gearbox crossmember
    Then fitted propshaft
    Then refitted starter so not a bad nights work
  17. #57
    Nov 2011
    eastham wirral
    584
    20
    Have filled in drain holes and seam welded chassis rails to floors on both sides plus a little repair to the inner sill
  18. #58
    Nov 2011
    eastham wirral
    584
    20
  19. #59
    Nov 2011
    eastham wirral
    584
    20
    Repaired sill step under back door just need to do other side
  20. #60
    Nov 2011
    eastham wirral
    584
    20
    Other side done, trial fitted cage
  21. #61
    Nov 2011
    eastham wirral
    584
    20
    Made some oversize floorpan plates for the roll cage and welded them in
  22. #62
    Nov 2011
    eastham wirral
    584
    20
    Been getting the cage multi points ready for welding its a nice tight fit
  23. #63
    Nov 2011
    eastham wirral
    584
    20
    Battery cable from boot to master switch then to starter, switch mounted where ashtray was
  24. #64
    Nov 2011
    eastham wirral
    584
    20
    Made a start on round turrets looking good so far
  25. #65
    Nov 2011
    eastham wirral
    584
    20
    One side all welded in
  26. #66
    Nov 2011
    eastham wirral
    584
    20
    Filled in around turret just got to do on top
  27. #67
    Nov 2011
    eastham wirral
    584
    20
    Turrets all finished firewall and parcel tray done
  28. #68
    Nov 2011
    eastham wirral
    584
    20
  29. #69
    Nov 2011
    eastham wirral
    584
    20
    Made turret mounts for cage
  30. #70
    Nov 2011
    eastham wirral
    584
    20
    New tank arrived need to crack on and get base fitted
  31. #71
    Nov 2011
    eastham wirral
    584
    20
    Looking a bit more tidy
  32. #72
    Nov 2011
    eastham wirral
    584
    20
    Fitted rear cage hopefully for the last time
  33. #73
    Nov 2011
    eastham wirral
    584
    20
    Tank stand welded in, when its painted can mount tank and run fuel lines
  34. #74
    Nov 2011
    eastham wirral
    584
    20
    Ran battery cable and clipped it to floor
  35. #75
    3,641
    Nice work mate.
  36. #76
    Nov 2011
    eastham wirral
    584
    20
    thanks didnt think anyone was reading this!
  37. #77
    Bodger mario r h santos's Avatar
    Sep 2011
    Portugal
    183
    I am. Good set of skills you got there mate.
    Keep up the good work.
    Cheers,
    Mário Santos.
  38. The Following User Says Thank You to mario r h santos For This Useful Post:
  39. #78
    Pit Crew gorilla1q's Avatar
    May 2009
    Cheshire
    1,345
    67
    Looking good mate I like the rear turret install need to sort the measurements so I can sort mine one of the jobs I'm dreading lol Keep it up and keep them pic's coming (I'm only down the road in Ellesmere Port )
    When I grow up I will have a MK1 Escort
    I must be all growed up now then and paying for it!
  40. #79
    Nov 2011
    eastham wirral
    584
    20
    Cheers mate I have the measurents for the turrets if you need them
  41. #80
    May 2009
    Cheshire
    1,345
    67
    That would be great mate I've had them for the 2 door but struggled to put them into 4 door design lol
