Page 3 of 4 FirstFirst 1 2 3 4 LastLast
Results 81 to 120 of 160
Thread: four door mk2 road rally project
  1. #81
    Aug 2012
    lampeter
    284
    Re: four door mk2 road rally project
    Good work mate keep going at it
  2. #82
    Mechanic danknight72's Avatar
    Nov 2011
    eastham wirral
    584
    20
    Been making the crossmembers for the sump guard using the drawings out of the works preparation manual
  3. #83
    Tyre Kicker Chris2k4's Avatar
    Mar 2013
    South Wales
    25
    Yes tidy car mate .
    The only way is sideways
  4. #84
    Oct 2008
    whitley bay
    2,436
    89
    Nice welding on that !
    Hexham and District Motorclub
  5. #85
    Nov 2011
    eastham wirral
    584
    20
    Thanks guys
  6. #86
    Nov 2011
    eastham wirral
    584
    20
    Finished centre mount for sumpguard will add angle supports when I trial fit to car
  7. #87
    Jan 2014
    Somerset
    31
    Nice work!
  8. #88
    Nov 2011
    eastham wirral
    584
    20
    Made a little bracket for the filter king the one supplied didn't look man enough!
  9. #89
    Nov 2011
    eastham wirral
    584
    20
    Made the front brackets for the sump guard came out quite well,
  10. #90
    Nov 2011
    eastham wirral
    584
    20
    Got my new radiator back today, it's got uprated cores and a hand made top tank-very pleased and historic legal
  11. #91
    Nov 2011
    eastham wirral
    584
    20
    Fitted rad with stainless cap heads, mounted fan with new plastic ties, fitted new hoses and thermostat
  12. #92
    Nov 2011
    eastham wirral
    584
    20
    Got seat tubes welded in on passenger side
  13. #93
    Nov 2011
    eastham wirral
    584
    20
    Made sumpguard brackets off a template off a friends new group 4 guard
    My old 309 on my first road rally as a driver
  14. #94
    Mechanic MCURZON's Avatar
    Nov 2006
    Bridgend
    743
    19
    Looks like this is going to be a really tidy car, great work
  15. #95
    Nov 2011
    eastham wirral
    584
    20
    Made a bracket for the ap handbrake cylinder, had to check because the inlets are different to girling cylinders!
  16. #96
    Oct 2013
    aberdeenshire
    35
    Good stuff ☺️
  17. #97
    Nov 2011
    eastham wirral
    584
    20
    Fully assembled pedal box have used gen girling cylinders and fitted the dash adjuster, I am using banjos for the feeds to the front and rear. The front goes to a bulkhead mounted tee piece then through the bulkhead and down the spring pan rails.
    Mounted the bottles on a alloy bracket I machined, have space for an extra cylinder if I go hydraulic clutch
  18. #98
    Nov 2011
    eastham wirral
    584
    20
    Got a pair of 2.8i rear brakes cheap so
    Stripped them and shot blasted them. Going fit new cylinders as they are only 7.50 each
  19. #99
    Nov 2011
    eastham wirral
    584
    20
    Made a clutch cable bracket as I'm running a crossflow with an rs type alloy bellhousing. I'm using a long rs2000 clutch cable that came ready with heat shield from rally and competition equipment.
    Tried the clutch and feels ok if a bit stiff
  20. #100
    Nov 2011
    eastham wirral
    584
    20
    Fitted handbrake bracket and modded handbrake lever
  21. #101
    Nov 2011
    eastham wirral
    584
    20
    I stripped the second hand ap master cylinder I had got cheap took it into work and cleaned it in the ultrasonic bath, came up well. I then fitted the seal kit i got from tweeks for 8 quid and mounted the cylinder. Fitted it to the bracket and attached the brake pipe with new copper washers.
  22. #102
    Spanner Monkey redhf's Avatar
    Jan 2006
    uk derbyshire
    58
    479
    164
    Your handbrake looks like it's plumbed in the wrong way round!.
  23. #103
    Nov 2011
    eastham wirral
    584
    20
    ap work the opposite way to girling with a m12 inlet at the front and a m10 outlet at the rear
  24. #104
    Oct 2012
    UK
    11
    Nice work mate, the mounted bottles look bang tidy. Did you make your pedal box yourself?
  25. #105
    Nov 2011
    eastham wirral
    584
    20
    No think its a rix engineering item I got second hand locally
  26. #106
    Nov 2011
    eastham wirral
    584
    20
    Removed the fuse box and fitted a new blade type fuse box mounted underneath where the old one was so didn't have to lengthen any wires. Made a stainless cover for the hole.
  27. #107
    Nov 2011
    eastham wirral
    584
    20
    Repaired near side rear wheel arch today, started off with this
    Ended up with this
  28. #108
    Nov 2011
    eastham wirral
    584
    20
    Repaired off side wheel arch and inner arch and closing plate
  29. #109
    Bodger mk22door's Avatar
    Jan 2014
    Yorkshire
    Fantastic build, good work!
    Love all the little home made touches, it's going to be an excellent car
  30. #110
    Nov 2011
    eastham wirral
    584
    20
    Thanks mate, finished the outer and inner wheel arch now and a small repair to the tank well.
    Going to attack the lower rear panel now
  31. #111
    Nov 2011
    eastham wirral
    584
    20
    Drilled all the spot welds out and removed the old back panel it wasn't that rusty but was bent to buggery!
  32. #112
    Aug 2014
    mansfield
    11
    keep up the good work
  33. #113
    Nov 2011
    eastham wirral
    584
    20
    Cheers mate, rear panel is now on fully welded
  34. #114
    Nov 2011
    eastham wirral
    584
    20
    My old bug on the tour of cheshire 2011
  35. #115
    Pit Crew Decade Plus User mista weava's Avatar
    Sep 2005
    Isle of Wight
    992
    22
    Nice thread mate.
    4 doors will be seen more and more in competition as the 2 doors thin out.
    www.rallycarsforhire.net
  36. #116
    Spanner Monkey lukem30's Avatar
    Jul 2012
    Uk
    35
    408
    78
    Great thread, your car seems to be having all the same repairs as mine needs, it's nice to see all the photos of the welding to make sure I'm doing it right.
  37. #117
    Nov 2011
    eastham wirral
    584
    20
    thanks luke,im toying with the idea of going xe like yours will do a few road rallies see how the 1700 crossflow goes
  38. #118
    Jul 2012
    Uk
    35
    408
    78
    The xe has been great, I think you would struggle to get the same sort of power out of another motor for the same cost of the xe convertion, and if it goes bang it's just a case of replacing it with another pretty cheap standard motor.
  39. #119
    Nov 2011
    eastham wirral
    584
    20
    Ground all the welds down on the back panel, going to get a thin skim of filler before some etch primer
  40. #120
    Nov 2011
    eastham wirral
    584
    20
    After a lay off to fit a new kitchen back on the escort
    Fitted spring hanger skid
