Page 1 of 4 1 2 3 4 LastLast
Results 1 to 40 of 160
Thread: four door mk2 road rally project
    Mechanic danknight72's Avatar
    Nov 2011
    eastham wirral
    584
    20
    heres my mk2 1300gl four door,i bought it from mull last october i got the train up from northwich to oban and drove it back-had no issues apart from it running hot above 60 so took it steady.first mod was some gen rs2000 wheels and some 175/70/13 yokohama tyres so its legal for historic road rallies,also bought a steering wheel boss from squires so i could fit my 3 spoke steering wheel.
    Nov 2011
    eastham wirral
    584
    20
    Re: four door mk2 road rally project
    next job was to sort out front brakes and struts so got some 2nd hand group1 bilsteins,then needed some steering arms and a new roller bearing top, bought some new 175 std height springs from squires along with some fancy nas bolts for the steering arms.Bought some reconditioned spaced m16 calipers from gs escorts and some rs hubs and new vented discs from squires.managed to get a new track control arm off ebay for 3 quid local and got another from a factors for 28.fitting struts meant opening inner wings out and re drilling the inner wing.ebay track control arm needed the inner bush drilling out as was too small.bought some new gen ford rs2000 track rod ends,one side came off like new the other needed a slot with the grinder.got the struts bolted on came to put the new calipers on-two problems!needed a spacer to centralise the caliper and the old bolts wouldnt fit the bilsteins as they are a 7/16 thread.ordered a kit off ebay with the spacer washers and bolts came to fit them today and the bolts were very tight but i carried on and ended up snapping one off in the strut!so took hub off the drilled the bolt out went to machine mart bought a tap and die set ran it down the threads and then ran the die down the new bolts which were obviously not right!anyway got it all bolted up and bled brakes and took it around the block but need brakes bleeding again but drives loads better
    Oct 2008
    whitley bay
    2,436
    89
    Looks good to me
    Have a look at my thread i road rally a four door too :-)
    Hexham and District Motorclub
    Nov 2011
    eastham wirral
    584
    20
    cheers mate your four door is a lot tidyer than mine!loved the pic of duffys mk2 i remember seeing that in the flesh must have been 91-92?
    Aug 2010
    west wales
    33
    31
    I like it. Glad to hear there's going to be another 4 door in the lanes.
    Nov 2011
    eastham wirral
    584
    20
    fitted some rear bilsteins nice and firm now at the back,bought a fresh 1700 crossflow for 500 quid has been lightened and balanced and has a 270 cam in so no screamer but should be ideal down the lanes.got myself a four branch and a brand new ashley sytem from squires along with a twin choke and manifold.got it running sounds crisp but crank is hitting sump so will be dropping front crossmember etc to drop it.got some quarter bumpers off a mate for 50quid some spotlight brackets(new from gs escorts) and best bargain is some super oscars for 32quid off ebay and they are mint.will pop some pics up soon
    Aug 2010
    west wales
    33
    31
    Sounds good. You had a bargain with the spots. What sort of pattern is the beam?
    Mechanic azz259's Avatar
    Aug 2009
    west wales
    487
    10
    Nice, get some more pics up. Where in west wales are you Greg?
    Nov 2011
    eastham wirral
    584
    20
    Sorted the sump out it was touching the crank in one tiny spot so adjusted it with the hammer,crossmember back on now,going to get a RS box tomorrow have a new bell housing got for bargain £100! Stripped paint off bonnet today was all cracked.oscars are the drive lens I think
    Nov 2011
    eastham wirral
    584
    20
    bare metalled the bonnet had a couple of dents to fill
    Nov 2011
    eastham wirral
    584
    20
    low mileage rs2000 box fork and quickshift £75 bargain
    Nov 2011
    eastham wirral
    584
    20
    Went and got some m10x1.5x40 cap head bolts so I could quick release the gearbox. Had to relieve the box slightly as the bolts go in from behind use a grinder,stone and drill bits so they would sit flush and go in straight
    Nov 2011
    eastham wirral
    584
    20
    40mm bolts just the right length
    Oct 2008
    whitley bay
    2,436
    89
    Glad you got it sorted mate
    You had any luck with the clutch ?
    Nov 2011
    eastham wirral
    584
    20
    Going order ap plate off buttons
    Nov 2011
    eastham wirral
    584
    20
    Cut out gear lever hole today got to move it back 70mm will weld it back in and plate in front
    Nov 2011
    eastham wirral
    584
    20
    Went to r.a.c.e today mick sorted me out with a pressure plate,fitted it been trying to get box back on going to have to drop crossmember I think
    Nov 2003
    Wirral UK
    6,740
    257
    Nice work with the gearbox, looks good
    http://escort.accelerator.org
  19. #19
    Nov 2011
    eastham wirral
    584
    20
    Took carpet out very pleased with floors only a bit of rot at the side of the foot wells original floors 33 years old tried the big tunnel in place have trimmed heater plastic at bottom time to cut a big hole now!
  20. #20
    Nov 2011
    eastham wirral
    584
    20
    All welded in now just need to sort out the crossmember mounts
  21. #21
    Nov 2011
    eastham wirral
    584
    20
    Drilled out the spot welds on the heater bulge found a bit of rot knew it was holed
  22. #22
    Jul 2010
    South Wales
    4,689
    221
    Fair play your tunnel went much better than mine I couldn't mate mine up to the original tunnel because it had been butchered before so i will have to fab that piece up. And the welding on mine isn't too clever.
  23. #23
    Nov 2011
    eastham wirral
    584
    20
    Yours looks fine mate, mine would have been easier if it had a flange all the way round like the one pictured on plr website!
  24. #24
    Nov 2011
    eastham wirral
    584
    20
    Made a start repaired the top of the vertical bulkhead and welded in the repair panel
  25. #25
    Nov 2011
    eastham wirral
    584
    20
    Then repaired the bits under the edge of the bowl
  26. #26
    Aug 2010
    west wales
    33
    31
    Quote Originally Posted by azz259 View Post
    You asking me? I'm in a little village called Dihewyd. The cars coming on great too, do you do the fabrication yourself.
  27. #27
    Aug 2009
    west wales
    487
    10
    Quote Originally Posted by GJH View Post
    You are joking? Right? I live in Dihewyd aswel
  28. #28
    Aug 2010
    west wales
    33
    31
    Its a small world!!! I'm at the coucil house oppostie the chapel as you head down through the village.
  29. #29
    Nov 2011
    eastham wirral
    584
    20
    Bulkhead and heater bowl done just needs a little bit of filler
  30. #30
    Nov 2011
    eastham wirral
    584
    20
    Spent the day cleaning the chassis rails and bulkhead scraping 30 years of grime off,welded on my home made gussets and did some seam welding
  31. #31
    Nov 2011
    eastham wirral
    584
    20
    Done some seam welding around the radiator surround and the front of the chassis rails, it's really sound and straight
  32. #32
    Aug 2010
    west wales
    33
    31
    Coming on very nicely with you. Are you going to keep it black or is it having a colour change!
  33. #33
    Nov 2011
    eastham wirral
    584
    20
    Going to be green I think! Seam welded inner wing fitted new wing rails made a strengthener
  34. #34
    Nov 2011
    eastham wirral
    584
    20
    Front panel off not to bad underneath
  35. #35
    Nov 2011
    eastham wirral
    584
    20
    Ready to fit new front panel, just have to paint inside radiator surround
  36. #36
    Nov 2003
    Wirral UK
    6,740
    257
    coming along nicely now, good work
  37. #37
    Nov 2011
    eastham wirral
    584
    20
    Thanks mate need to decide what colour to paint it today
  38. #38
    Nov 2011
    eastham wirral
    584
    20
    Have decided on ford frozen white painted behind front panel
  39. #39
    Nov 2011
    eastham wirral
    584
    20
    Front panel is now fully welded
    Fitted new wing rail on near side and trial fitted new wing
    Dragged it out on the drive to turn it around and work outside bi more room than the garage
  40. #40
    Aug 2010
    west wales
    33
    31
    Coming on good with you.
