Results 1 to 4 of 4
Thread: cosworth injecters
    Feb 2009
    aberdeenshire
    891
    87
    cosworth injecters
    looking for advise on injectors ? want to run hopefully 300 ish bhp ? what injector would suit? thanks steve
    3,242
    Re: cosworth injecters
    Depends on what the ECU can use! Ford / Cosworth OEM ECU needs low impedance types - most aftermarket types will need high impedance ie. 12 - 16 ohm. Sizewise between 350-400cc @ 3 bar fuel pressure should support 350hp but bigger would allow a bit of headroom.
    Mar 2008
    west bromwich
    1,861
    803 known as greens will give you around 330 bhp with an off the shelf chip if your useing the standard Weber ecu
    Feb 2009
    aberdeenshire
    891
    87
    thanks for advise lads,
