Results 1 to 6 of 6
Thread: hi all wonder if any one had come across this
    Sep 2010
    S WALES
    524
    25
    started car for the first time sunday night first turn she fired up great but after 5 mins of ticking and the exhaust maniford got so hot it set fire to the 600 deg c heat mat around the inner wing luck i was close by i know the maniford is only about 10 to 12 mm away
    should i rap the maniford to be on the save sid e ok the carbs may be running weak but can not even run it to set it up lol lol
    its a tony law maniford is it ok to rap the maniford apart for saving my car for burning many thanks dean
    Clint's Avatar
    Jul 2001
    940,204
    Re: hi all wonder if any one had come across this
    1 post in 1 section will do !
    Plymouth
    899
    by wrapping the manifold it will reduce the temp in the engine bay but will manifold will get hotter and probably have problems later with cracking, sort out the fuelling and timing it it will reduce the hot running, i run a big stainless simpson manifold and have no problems without the wrapping
    Racer Decade Plus User sambo's Avatar
    Oct 2005
    Bexhill on sea
    1,934
    107
    Deffo down to the mixture! It shouldnt be getting that hot quite so quickly!!
    Feb 2007
    Hillingdon
    2,107
    21
    mixture id reckon
    My Project... Fiesta D-TEC
    East Sussex
    58
    5,023
    Incorrect cam/ignition timing and/or weak mixture will cause the manifold to get excessively hot.
